Fred3
Fred3's Achievements
SpecialWarr, I need yr help to correctly identify this part.
95 Pathfinder XE. You have been helping me diagnose & cure why pathy won't start.
Here are the pictures of the part, I beleieve is called the ignition control module, that tested Good at Autozone. is this really the ignition control module ? or power transistor ?
Thanks again for yr expertise and patience with me. New coil should be in today and really hoping that is the cure
I need help to get my 1995 Pathfinder XE, auto trans going again. Was cutting out and then stopped all together. Replaced battery, dist cap, fuel filter, Coil checked out good at AutoZone but not sure if it was checked correctly. No spark and will not start ( obviously ) Had speaker hooked up in back of rig, that were stolen and at that time found the positive wire from them hanging down. That is when my problems started with engine cutting out, Could that angling positive wire have shorted out my system ??
Thanks. I need all the help I can get, Fred
For technical help it is best to use a standard forum topic, like the one you created here HERE.
I am going to lock this Status Update so that replies trying to help are centered in the thread for simplicity
