Everything posted by mechanic58
Help me out with your knowledge of axles
mechanic58 replied to Charlie_Brown's topic in 90-95 WD21 Pathfinders
If you're just running a stock or near stock Nissan powerplant there would be no need to use a 60. Those are dumptruck parts. A Dana 44 is more than sufficient for this application. -
92 MT 5th Gear Whine/Loud ass intake noise?
mechanic58 replied to Wacky_Pathy's topic in 90-95 WD21 Pathfinders
Bearings. It's fixin to sh!t the bed. Good luck. -
Source for 95 Pathfinder spare tire cover exterior rack
mechanic58 replied to alburk's topic in 90-95 WD21 Pathfinders
I bought a plain black nylon one with a drawstring on it on eBay for like $4, shipped to the house. -
Hell, just get a sawzall and cut the whole roof off while you're at it!
As much work as it is to R&R one of these transmissions - I cannot imagine in a million years putting a different, used one in place. Why would you do that? What a waste of time and effort. Shoulda just rebuilt the one that was in it. Or at least removed it and took it somewhere to have it rebuilt if you can't do it yourself. Now you got a pretty significant issue. Good luck!
I went to a race one time that was ALL Dodges and nobody won.
1995 Pathfinder XE electrical problems
mechanic58 replied to Fred3's topic in 90-95 WD21 Pathfinders
Ignition coil failures are very rare, especially this style. -
https://www.ebay.com/itm/Ultra-Wheel-051-5883K-Type-050-051-Wheel/161460384442?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
I just put a set of 15x8 Ultras on mine, they have a +19 offest (5.184" backspace) and they fit perfectly. The Ultra p/n for this wheel is 051-5883K. I put 31x10.50's on em. They do not stick out at all. -27's are going to stick out and look like hot vomit. These wheels were $80 ea, shipped, on eBay.
a/c compressor fan clutch grinding noise
mechanic58 replied to PamPoovey's topic in 90-95 WD21 Pathfinders
You had to google that, didn't ya? Amateur. lmao -
95 Pathfinder Interchangeable parts?
mechanic58 replied to CrystalLakeKillr's topic in 90-95 WD21 Pathfinders
Common failure with these. I just overhauled mine. Ended up having to replace the front pump (due to a severely worn stator) and the reverse drum. Those parts are not commercially available anymore either btw...I got lucky and found some good used parts on eBay. All total it ended up costing me $500 to fix the transmission - myself. New converter, good used front pump, good used reverse drum and a full rebuild kit. And FIVE days of my time. I was crippled for 10 days afterwards too. GOOD LUCK. -
1994 Pathfinder - Reluctor / Distributor Problem ?
mechanic58 replied to PathinTX's topic in 90-95 WD21 Pathfinders
Probably the reluctor or magnetic pickup as some refer to it as. It's inside the distributor. They commonly go bad with old age or high miles (lots of heat cycles). Generally a very cheap part if you can just buy the part. Not sure what you'll get into on this though. May have to buy a whole distributor to get it. -
Hi. A/S/L? -
Also - I'm dreading dealing with the EGR tube. :|
Anytime you have to do work at the exhaust manifold level you run the risk of breaking studs. No amount of penetrating oil can prevent it either, in most cases. Really, the only correct way to to get them apart is via heating them with a torch, which isn't always an option either. Mine is leaking like a stuck pig from about 10 different locations between both exhaust manifolds. I have decided to leave it alone for now. I want to put headers on it, but I just can't muster the gumption to dive into that train wreck waiting to happen. I've recently had my y-pipe off, so not really anticipating a collector stud problem. What I'm worried about is the cylinder head studs. I have at least 3 either broken off or missing already. I'm hoping they just backed out and are missing.
Should. I have fabbed lots of flanges out of 3/16 and 1/4 plate. Not a big deal.
*crickets*
You can buy weld-in o2 bungs on ebay. Install the headers, cut the front flange off your old intermediate pipe (or cat) and just have the muffler shop make a new catless pipe using the old flange. They can install the o2 bung in the same exact spot. I have done this countless times. Fixing to do it to mine here shortly. Both of my cats are rattling like bastards, its about to drive me batty.
A small block Ford is a better choice for a V8 swap. They're significantly smaller than a SBC and they have a front distributor. If I was going to put a V8 in mine that's the way I'd go. However, I just overhauled the automatic trans in mine and the VG30E that's in it runs perfect. I don't reckon I'll mess with it. -
Cut the cats out and throw them in the garbage. That's my advice.
! (I'm 47) -
Were you a show girl? (It's ok to lie to me) -
I see. So I'm guessing your trailer must be newer than the ones in the background in your signature pic. Gotcha. ;-)
