thehillboys
Everything posted by thehillboys
  1. Went with KYB struts with MOOG OEM springs and added a 1 1/2" spacer. added 2.5" to a blown front end. The ride is superb. I am sure a bit softer than EMU or Rancho. Used the Land Cruiser spring on the back. Love the combo. Even with the 2" rake.
  2. One note when installing the springs, try and get it done without removing the bump stops. Mine were bolted in and we thought it would be easy to remove them to make the installation easier. Both bolts broke off. A big pain drilling them out. Just and FYI if it can be done without removing them.
  3. One note when installing the springs, try and get it done without removing the bump stops. Mine were bolted in and we thought it would be easy to remove them to make the installation easier. Both bolts broke off. A big pain drilling them out. Just and FYI if it can be done without removing them.
  4. My final numbers: Rear went with 9447 and Bilstein 1525 shocks LR - 34 1/4" to 38 1/2" settled to 37.5" net 3 1/4" RR-33 3/4" to 38" settled to 37.5" net 3 3/4" 1 1/2" spacer with KYB struts. LF - 32 1/2" to 35 net 2 1/2" LR- 32" to 35 net 3" note on a slightly uneven shop floor. Today back was 37.5" and front was 35" for 2.5"rake both sides on my level driveway.
  5. Working on it this weekend, should have some numbers for you tomorrow.
  6. My thermal switch Nissan part number 16391-31u00 is leaking on my R50 and I am going to attempt to fix. I am first going to attempt the O-ring replacement. Would love a detailed description of the process if anyone out there has had experience with this. Not really in the mood to spend $125 if all it is is a 50 cent O-ring. Would love the help.
  7. My thermal switch Nissan part number 16391-31u00 is leaking on my R50 and I am going to attempt to fix. I am first going to attempt the O-ring replacement. Would love a detailed description of the process if anyone out there has had experience with this. Not really in the mood to spend $125 if all it is is a 50 cent O-ring. Would love the help.
  8. Going to lift the weekend after this. Wondering if there are any tips for installing these springs such as what to look out for and what needs out of the way. I do have a mechanic helping me but he probably has never put Land Rover front springs on a 1996 Nissan Pathfinder rear before. I am also putting Bilstein 5125s on the back and know there are a few tricks for those. Tips and hints for the front would also be helpful. (KYB with 1 1/2" spacer for a 2" lift on front.) Do have Camber bolts. One thing I am getting mixed messages on is torque. "Flurry" give 29 ft lbs much lower than Nissan Specs. and so on. Torque for Camber bolts would be helpful also. I Do not want to highjack this post and will start a build thread of my own, just had those thoughts on my mind. Thanks
  9. Micah That looks bad ass. When you get a chance can you send us measurements comparing front and rear. Right now my front is sagging really bad and I have 2" of rake from back to front. Yours looks good, just wondering the difference.
  10. I will look at the top plate and may just re-use it and then order new bearings as they are not too expensive.
  11. Any recommendations on Caber Bolts? Also is their any other recommended maintenance and or changes I should think about doing when lifting? All parts are in with shocks on the way (Bilstein). 9447 springs on the back, new Moog on the front with 1 1/2" (2"lift) spacers, new KYB struts All I lack is the Cam Bolts. Thinking about doing the brakes while it is taken apart and changing pads etc. and bleeding lines with new brake fluid. The pathfinder has 137,000 miles purchased in 1997 with 20k miles.
  12. I am going with KYB front struts and rebuild kit New Moog front springs Fluery's 2.0 spacer for front ( being a bit safer) NRC9447 for rear Cam Screws Bilstein shocks I am going to build some camping drawers for the back which will bring the back down a bit
  13. NRC9447s on the way with KYB struts and spacers
  14. Purchased the Pro Comp rims 15x8. They will stick out a bit but should work.
  15. I am going with the NRC9447 for the back with ? shocks. I am thinking this will give 2- 2 1/2" in the rear. I am going with KYB struts in the front. My question is what could give me 2" of lift in the front via spacers and springs? My front springs are probably a bit saggy if I re-use them. I was t thinking new springs up front with a spacer. Are there any suggestions and combinations that anyone is using that is working well? Also has anyone found a complete KYB strut with spring included?
  16. Rim is 15x8. Not sure their is any legal limits in New Mexico. Half the vehicles in my are fling mud. lol. I am going to mount one today and check it out.
  17. Will these fit over brake calipers? And will they stick out too far? Also they were off a Toyota 4 Runner 2000 ish. I am thinking the Nissan and Toyota rim would be the same model? Need advice, I can save money buying used.
  18. Are the KYB shocks longer than stock? If so do you know how much longer or the model. number. Thanks
  19. Are the front spacers you are using true 2" or is your final lift 2" with slightly smaller spacers?
  20. Also what shock are you using in the back with the NRC9447 coils?
  21. A bit confused. I was looking at this chart and the NRC9447 is 14.8 inches where the NRC9446 is 15.19 inches. Has anyone found which one will give 2" of lift in the back? Liking this option over spacers in the back. http://www.red90.ca/rovers/springinfo.html
