thehillboys
thehillboys last won the day on February 13 2018
thehillboys had the most liked content!
1996 pathfinder
45+
XE
1996
Farmington New Mexico
Country
thehillboys's Achievements
Went with KYB struts with MOOG OEM springs and added a 1 1/2" spacer. added 2.5" to a blown front end. The ride is superb. I am sure a bit softer than EMU or Rancho. Used the Land Cruiser spring on the back. Love the combo. Even with the 2" rake.
DIY winch bumper 'builder' brackets
thehillboys replied to hawairish's topic in 96-2004 R50 Pathfinders
Maybe -
Land Rover rear lift spring install
thehillboys replied to Bax03SE's topic in 96-2004 R50 Pathfinders
One note when installing the springs, try and get it done without removing the bump stops. Mine were bolted in and we thought it would be easy to remove them to make the installation easier. Both bolts broke off. A big pain drilling them out. Just and FYI if it can be done without removing them. -
MOOG new OEM -
My final numbers: Rear went with 9447 and Bilstein 1525 shocks LR - 34 1/4" to 38 1/2" settled to 37.5" net 3 1/4" RR-33 3/4" to 38" settled to 37.5" net 3 3/4" 1 1/2" spacer with KYB struts. LF - 32 1/2" to 35 net 2 1/2" LR- 32" to 35 net 3" note on a slightly uneven shop floor. Today back was 37.5" and front was 35" for 2.5"rake both sides on my level driveway. -
Working on it this weekend, should have some numbers for you tomorrow. -
My thermal switch Nissan part number 16391-31u00 is leaking on my R50 and I am going to attempt to fix. I am first going to attempt the O-ring replacement. Would love a detailed description of the process if anyone out there has had experience with this. Not really in the mood to spend $125 if all it is is a 50 cent O-ring. Would love the help.
Cool Thanks for the info -
Going to lift the weekend after this. Wondering if there are any tips for installing these springs such as what to look out for and what needs out of the way. I do have a mechanic helping me but he probably has never put Land Rover front springs on a 1996 Nissan Pathfinder rear before. I am also putting Bilstein 5125s on the back and know there are a few tricks for those. Tips and hints for the front would also be helpful. (KYB with 1 1/2" spacer for a 2" lift on front.) Do have Camber bolts. One thing I am getting mixed messages on is torque. "Flurry" give 29 ft lbs much lower than Nissan Specs. and so on. Torque for Camber bolts would be helpful also. I Do not want to highjack this post and will start a build thread of my own, just had those thoughts on my mind. Thanks -
Micah That looks bad ass. When you get a chance can you send us measurements comparing front and rear. Right now my front is sagging really bad and I have 2" of rake from back to front. Yours looks good, just wondering the difference. -
I will look at the top plate and may just re-use it and then order new bearings as they are not too expensive. -
Any recommendations on Caber Bolts? Also is their any other recommended maintenance and or changes I should think about doing when lifting? All parts are in with shocks on the way (Bilstein). 9447 springs on the back, new Moog on the front with 1 1/2" (2"lift) spacers, new KYB struts All I lack is the Cam Bolts. Thinking about doing the brakes while it is taken apart and changing pads etc. and bleeding lines with new brake fluid. The pathfinder has 137,000 miles purchased in 1997 with 20k miles. -
I am going with KYB front struts and rebuild kit New Moog front springs Fluery's 2.0 spacer for front ( being a bit safer) NRC9447 for rear Cam Screws Bilstein shocks I am going to build some camping drawers for the back which will bring the back down a bit
