haydenmidd12
    1998 nissan pathfinder le stock need help to change that
    Skilled/Experienced Mechanic
    brandon,MS
haydenmidd12's Achievements
  1. I was wanting to know the same thing I have read the reviews and some have seen improvement and some haven't
  2. Has anyone tried the do it yourself JCR bumpers? Also are the widths of the jeep xj and the r50 about the same width?
  3. Does anyone know the steering shaft length for a 3 inch SFD?
  4. So they are using the honda steering or parts form the pathfinder and honda to make one ? and im going to look at prices today for the steel to drop down the subframe and if it doesnt cost that much i will probably end up going with the woodward steering just to be safe and not have to worry about modify the one i have now. unless someone has down the modify route and will help me out.
  5. Instead of ordering a the u-joints and the shaft is there a way to modify the stock steering shaft for smaller SFD like a 2.5" SFD? Is there a way to make like a spacer for the steering shaft instead on buying a whole new steering linkage setup? If anyone has modified the stock one or maybe used other steering set ups from a differant vehicle will you let me know how you did modify it and if possible post a picture of what it looks like even if it is on your Pathfinder.
  6. Is SF creation going to make a SFD? It would be awesome if you guys made it to were people can buy the steering extensions. thats the only thing holding me back from doing it
  7. by modified how would I do that and where could I get a new steering link from?
  8. Where can I buy a SFD steering linkage from? or is there a way to make one?
  9. 5.- Unplug the steerig wheel conection to the rack and the pressure senso. This is the joint and the replacement part: Where did you get your steering linkage from thats the only thing I need and don't know where I can order one. and is there anyway i can just make one?
  10. For the strut spacers does it really matter about the 8 degrees that they have to be slanted?
  11. I want to get my truck lifted alittle in the front i have a 1.5 inch lift but it doesn't really effect anything. so i would do like a 3 inch subframe drop
  12. I am thinking about doing a 2inch subframe spacer and doing a 2 inch strut spacers with a 1 inch or so front lift coil. and I don't think ill run into steering issues dealing with steering linkage
  13. and what do you need for the 3 inch sub frame drop
  14. Well I am only 2wd and I know people ask why lift a 2wd but Its like why do people at SEMA have 2wd but still. My truck has a natural nose dive. I will probably end up doing a 4 inch sub frame drop and just have the 2inch ac coils for the rear. and have a little squats and run 33s and 22x14 american forces I have a set in my garage I will probably put on there.
