Rockclymr
Rockclymr last won the day on December 13 2020
Rockclymr had the most liked content!
    ARB Frt bumper, 3"Body lift, ARB Lockers (Frt & Rear), 2000w Inverter w/ dual Batt, few other minor mods, Lots of trail induced pinstriping and character...
    Skilled/Experienced Mechanic
    Choose
    Serious Off Road Enthusiast
    XE
    Tennessee
3,895 profile views
Rockclymr's Achievements
  1. Hello everyone, was wondering has anyone disabled or completely removed the ABS system on their Pathfinder? A search of the forums yields 0 results Since I SAS the front to a Dana 44, running a larger Master Cylinder. replacing lines. etc. was thinking I might do away with that whole system since I wont be doing any street driving anyway. Thoughts or any info would be much appreciated.
  2. I have the exact same problem with mine and have found noting on it either except a couple of the lids. not one have i found in a jy pathy in years of looking. what i plan on doing when i get back into interior upgrading is machine one out of 1/8 steel plate with tabs on each side to mount it to the lower box
  3. @hawairish https://www.facebook.com/groups/170483783286708/permalink/1421205021547905/?__cft__[0]=AZUnhvQ6Z2Ea0JunMqNorFetAPgLHCLwv53EQkN05NtstkJtun4gfPWhlvy2GoxSUSMHiySfIHYiU6KGFrcXqKNrx2yOH5aAjxVfejWCYyq2Q0w127o1wzvG3rR2E-D_f2cBL5iTtmXJRDhdBftDx4OjTm0sEr5Zwn5kX5hOgzpsNIRFCsTYqsk8mAlQIcnLOlA&__tn__=R]-R This should take you to the official post on his page for the raffle. Still some open spots available last time i checked but filling up fast
  4. Looking for a Xterra pickup tube to finish out the engine swap. if anyone has one available or could pull one at a local jy.pm me please. No longer available to buy from nissan and no jy anywhere around here has one i can rob
  5. Hey everyone. posted this on the Fbook group but thought Id share here just in case someone might want to get them while available. Bonney Motorsports has gearsets available for the TX10 case atm. Jared told me he still has 5 sets in stock with one reserved to a raffle he's doing. Tickets are $20/each with a limit of 3 per person w 50 tickets total so may want to get in on that at least and possibly get lower gears for $60 bucks or less. cn get in touch w/ Jared here www.bonneymotorsports.com
  6. Anyone talked to him lately or ordered anything recently? I placed an order for some DT headers back on the 15th that he said he had & got a confirmation the same day but haven't seen anything on them shipping and no response when I've messaged him. My bank had a memo on my account for the last week for the transaction but deleted it today since he never processed it on his end. so guess just wondering if anyone else on here has had an issue or what might be going on.
  7. Was just reading through this thread and was just curious as to why you might prefer a mechanical locker other than maybe the price? I put air lockers in both front and rear years ago and have had 0 issues other than having to replace the compressor pressure switch. I know they were a bit pricey compared to welding one up or going mechanical but it also allows me the option of running open on the street, lock front/lock rear/lock both depending on the driving conditions.
  8. old fashioned pipe wrench will either get it out or shear the head off... either way you get the cam gear off then you can get a bite on the bolt shaft. If you cant find a replacement local, pm me, I've got several.
  9. Hey Everyone. Finally getting the front end together on the SAS and with looking at the coilover spring rates got to wondering if anyone else has here has a 3 link setup w coilovers and what they were running. Since there are alot of variables ie shock angle, mounting point, etc. there is no perfect answer to this anyway but would appreciate any responses on current spring rate, ride quality, average sprung weight and any other input that might save me from buying springs then having to go through swapping them out for higher /lower ppi ones.
  10. We have plenty of JY around here. the problem is finding Nissans especially older ones that haven't already been stripped. See plenty on the road but that's the thing about them. if you do routine maintenance they'll run pretty much forever. I haven't babied mine at all and it's spent as much time off the road as on but never overheated it, kept the oil changed, timing belt ,etc. put an external tranny cooler on it and undercoated the entire body/frame right after i bought it new (not to mention all the mods I've done to date) but 320K miles with no major problems and 0 rust issues says alot about the quality of the vehicle. Don't see that in most vehicles these days for sure. There are plenty of other NPORA members in your area so might want to make an effort at getting in touch with a few that could point you in the right direction. maybe even some that are close enough to lend a hand with your project if the need arises
  11. Shame you live so far away. When I went looking for mine took one day to find 2 xterras completely intact Bought the whole motor for $350 w less than 70K miles on it and they pulled it for me. I get mine back in the truck thinking about getting the other one just to build .If you cant find one though worth using and want to cover shipping, can get it pulled. stripped down to just the things you'll need and send it your way.
  12. The VG33 Valves are significantly larger so would use those heads if available Just put the VG30 cams in them as the VG30 is a slightly higher lift/duration. Doing so will give you some increased torque on the low end. Also make a note of the cam gears as yours will have the square toothed gears/belt and the VG33 will have round tooth ones. Use the round tooth ones from the VG33. The brackets probably wouldn't be a big deal but the water pump housing will also need to be cut down on the right side to fit to the VG33 oil pump housing. It doesn't look to be a problem if you have some experience doing that sort of thing but if it was me id take an old pump and test cut/fit first before i went and cut on a new one. The harmonic balancer adapter is not something the average person can just make up since the VG33 crank has a larger snout than the VG30 in that has to be a tight tolerance or you'll create some major problems in a short time That also means you have to have the VG33 oil pump and lower timing gear cover available to reuse. Would definitely recommend you getting in touch w MR 510 about that. PM me an Email and I will send you the Info as I don't know how to add a link here to his member profile. if someone reads this that does, please feel free to do so.
  13. Because I am in the process of doing this myself you will need to do some modifications to your Water pump, the adjustment brackets for the alt & power steering and will need an adapter for the crank to reuse your VG30 crank pulley.. I got that all done by MR 510 so made it all pretty much a simple swap. I use the VG33 heads w/ the VG30 cams since had them.
  14. There isn't enough left in the pan if you let it drain for a while to worry about as after you run it up to operating temp again it will evaporate off and mix in to the egr system.
  15. It's very possible. replacing them is definitely the best route to go as cheap as they are but flushing the motor out would be a big priority for me. I usually take the oil filter off, remove the drain plug. then take a 1 gallon pump up sprayer of kerosene and wash the whole engine out anytime i have a valve cover off for any reason. that way i can flush out the oil passages and clean up any varnish build up. let it all drain good the coat everything w fresh oil before closing it up.
