amfq120
amfq120 last won the day on March 18 2012
amfq120 had the most liked content!
    93 pathy, 31 a/t, open rear, quarter million miles, auto
    XE
    Washington
  • Interests
    The pathy, mountainbiking, outdoors
3,235 profile views
amfq120's Achievements
NPORA Regular (2/5)
6
  1. I had the General Grabber AT2's on my pathfinder and they were amazing on and off road. I highly recommend them, especially since they are cheaper.
  2. I have a 93, how can I tell what interval mine has?
  3. I found this article from car and driver circa 1990. ENJOY! http://m.caranddriver.com/comparisons/1991-ford-explorer-eddie-bauer-vs-gmc-s-15-jimmy-slx-isuzu-trooper-ls-jeep-cherokee-laredo-mitusbishi-montero-ls-nissan-pathfinder-se-and-toyota-4runner-sr5-archived-comparison-test?build-2015112218
  4. That's where I have it set, would it still not start even if it was close? I've been smelling hot electrical from somewhere between the battery and firewall, it's not the fuses there, they don't smell or look burnt. I also heard a rapid clicking noise coming from right behind the engine above the trans...starting to think I may have blown something somehow.
  5. I'm following the Haynes manual to the best of my ability. from what I can tell the number 1 cylinder is the front left one, I follow that wire to the distributor cap and then point the rotor at that while the crank pulley is on the second Tic which should be TTC
  6. I've tried turning the key a little until the timing marks are aligned roughly, and then inserted the distributor with the rotor pointed towards the number one cylinder, but it still won't start.
  7. So my Pathfinder had a little bit of a stutter occasionally when I press the gas more than half throttle. I pulled the distributor out to try to turn it one tooth hoping that the timing was just off a little, but now it won't start. I smell a little bit of hot electrical smell. Any advice on what I'm doing wrong or what I need to do to get it running? I've tried turning the key just a little bit until the timing marks are visible on the crank pulley
  8. got it guys, thanks a lot for the advice.
  9. Replaced the upper ball joints on my 94 pathfinder, very easy. The lower ball joints though can't be taken out without the cv joint be moved out of the way, which requires the hub to be separated from the cv joint. I cannot get the allen wrench bolts loose for the life of me. All of them too. Any advice? I'm going to try to warm up the hub and then try to loosen it tomorrow. I dont' want to cut or grind them off because I don't want to spend more money on the IFS BS.
  10. I had the same problem with my 94 auto. When RPM's would drop when shifting to overdrive on the freeway it would bog. What fixed mine was replacing the coolant temp sensor or the engine temp sensor? Its a gold one that looks like a spart plug. It just under the upper radiator hose on my 94.
  11. That is a cost effective idea for the most part. However, you'll be much better off buying a Grassroots4x4.com centerlink ($250), Idler arm brace from 4x4parts.com ($30) and using that extra money to upgrade your sway bar bushings, strut rod bushings, etc. Not that the calmini kit isn't good, but what do you do when you need to buy replacement parts for their kit, or after so many miles you want to replace bushings...they cannot be found and new parts are not sold individually. Also, speaking from experience, the closer to OEM you keep your rig, the easier it will be to work on and buy parts for, and the cleaner it will look. Either way, good luck
  12. I had a weird sputter at did the timing, engine coolant temp sensor (at the front of the engine, easy and cheap) and one of the two fixed it
