Everything posted by ONCEBITN
Moving Out Of State Q's About towing the Qx4/Pathy
ONCEBITN replied to ONCEBITN's topic in 96-2004 R50 Pathfinders
can i pull the rear shaft and tie it up, i dont think i can afford the full trailer -
looking for ipod aux install, how to hook up 3.5mm hookup?
yup want the clean look, i like the stereo the way it is but want to be able to play my ipod -
come on does any one know how to solder in the 3.5mm into the cd changer setup -
yea but i had seen a write up where some one soldered in the jack on the board and plugged in the ipod and used cd changer button to change to the input -
ok, will do
well ive adjusted it again just like the video and im still getting the issue, but no lights in relation to it
yes i dont feel it unless stopped or letting off the gas, it dosent happen when running
yes i am, the only issue im running into is the with the trans, im trying to find out if i need a diff trans or if i can use the trans i have, reason being is my cluster for the diesel swap only goes to 3k so i am worried about shift points and bogging, but doing the measurements it looks like it will bolt up
im getting the parts together myself, im gonna use a monsterdog adjustable fuel pump with a water seperator kit with the stock tank, as for the measurments the trans seems like it will bolt up to QD32ETi
i did the tps adjustment at least i think i did it right, but ive been having this weird like fuel bump when stopped with the truck in gear it dosent do it all the time but its annoying, could this be plugs wires or cap and rotor
these are the codes i pulled form the ecm, the light went off and hasnt come back on yet p0120 p0733 p0510
ok so I searched but couldn't find what I needed, the 4wd light comes on and the wheel indicator light went off, I need the procedure to check the blinks to see what's wrong, and a list of what they mean, I'm ony phone so if some one could copy paste I would appreciate it
P1140 code and engine ticking. HELP PLEASE!
ONCEBITN replied to mcbooth's topic in 96-2004 R50 Pathfinders
im not familiar with the knock problem but here is a link to a relocation i guess to see if it fixes your problem http://www.nissanpathfinders.net/forum/topic/34574-knock-sensor-relocation/?hl=%2Bknock+%2Bsensor+%2Brelocation -
looks good, i have a dip gun for doing sprays, but i mostly do clear sprays to protect my paint
i have a newer frontier and average about 17 with 4x4, and i average about 17 with my Qx4 as well, welcome aboard
Looking forward to good times in Pathfinder
ONCEBITN replied to ajtbone's topic in New People Start Here!
welcome, this board is fool of awesome people, pun and play on words intended, lol really tho there are alot of great people on here so if you have any questions ask -
New Pathfinder owner and headscratcher
ONCEBITN replied to RamboRedRex's topic in New People Start Here!
i recently did water pump, timing belt, all pullys, alternator, main power relay, battery, spark plugs wires and cap and rotor, and all new belts, these trucks can set you back a few dollars but in the end its worth it, i dont have to mess with the truck for at least 35k now, so do all you can while you can, oh and welcome -
love the older body style, welcome aboard
welcome aboard
good looking rig, does it work in any other gear, if so could it be tied in with the tq, also welcome
welcome aboard
my driver side boot is torn all the way around and the joint looks good, im gonna use the dorman quick boot wich bolts on so the axle dosent have to be removed, any one have any helpfule hints on how to remove the old one and install the new one. http://www.autozone.com/autozone/parts/Dorman-Quick-Boot-CV/1997-Infiniti-QX4/_/N-j9odlZ6o205?itemIdentifier=491374_962617_24880_
here is my magnaflow clone, its quite but not to quite and has no drone or extra noise, deleted the resonator and did a turn down
