tdurb1327
    Screwdriver Mechanic
    Choose
    Choose
1,748 profile views
tdurb1327's Achievements
  1. So just found out today from a mechanic friend that the sub frame supporting the left front suspension is shot. Knew this was coming. Both sides in front of the doors were rotting bad with the cancer. So if anyone wants it whole for parts I will sell it. Has AC lift and locking hubs. 3.3 Motor has 150,000. Has hitch also. Sent from my iPhone using Tapatalk
  2. I would go with the AC springs. I have them and it takes a lot of weight to make it sag like the factory ones. Sent from my iPhone using Tapatalk
  3. I have the AC lift and have 32's on the factory 16" wheels. 1" wheel spacers cleared the struts. Just had to remove mud flaps to prevent rubbing. Sent from my iPhone using Tapatalk
  4. Yes. Looks good. I bought 1 inch spacers and took off front mud flaps and no rubbing at all. Sent from my iPhone using Tapatalk
  5. Damn. That's more than I paid for my Pathy! Sent from my iPhone using Tapatalk
  6. Does a 95 carrier fit on a 2000? I seen one for parts that had one. Sent from my iPhone using Tapatalk
  7. Here's a pic with my 2500 Chevy. Bumper is actually higher on the Pathy! Sent from my iPhone using Tapatalk
  8. 2000 SE with 32's Sent from my iPhone using Tapatalk
  9. You can see where I used the grinder in the second pic. I primed it after. Disappointed the drivers side didn't fit the same. They are the GR2 struts btw. Sent from my iPhone using Tapatalk
  10. Ok. I'm going to need spacers lol. The drivers side is rubbing a little too much for comfort. It's rubbing on the outside of the tread. The passenger side has no rubbing for some reason. Maybe cause it needs a balljoint still that I haven't installed. I went from 255/65/16 to 265/75/16 or 32's. No problems with it rubbing the fender or trim while turning even in reverse. I ordered 1" spacers which will give me the room away from the strut I need. Sent from my iPhone using Tapatalk
  11. Yes you can technically . Found that out today. Tires are rubbing the bottom strut perch. Tires do not fit under the strut like it should. I used the angle grinder to shave some excess metal off to right where the spring is sitting. I haven't got to test drive it yet to see how it works. Seems I have more room on passenger side than the drivers side. The back tires fit fine. I can post some pics tomorrow. I'm keeping my fingers crossed I don't have to buy spacers. Sent from my iPhone using Tapatalk
  12. Yeah. I bought used 265/75/16 off a 2002 junkyard pathfinder and hope they will fit. Different rims on that one. Sent from my iPhone using Tapatalk
  13. What is the biggest tire I can get without spacers or different offset rims? I know this has been talked about before but can't find it. I'm looking to get 265/75/16 but was wondering if I could go bigger? Cutting and trimming is no issue cause it has cancer already. Sent from my iPhone using Tapatalk
  14. Install some manual hubs and that will make them last longer too. Sent from my iPhone using Tapatalk
