dirtbike23
Everything posted by dirtbike23
  1. thanks guys...soon as i open it up again ill update you...
  2. wd21s were released here late 90s wherein it was already superseded..Z24 & TD27 NA are the variant..turbos are japan import & are converted from RH to LHD. there are R50s but are also japs import. ill try to inspect the internals perhaps in near future to answer my confusion.. thanks for the inputs sir..
  3. bottle jack test..jack up one wheel put tranny in gear and drive off the jack its a 99 (released here in phils).. painted it during my oil change and visual inspection of internal. hope this help.. [/url]">http://
  4. yes...its on neutral...tried also the bottle jack test with ebrake assist...no success
  5. yes...its on neutral...tried also the bottle jack test with ebrake assist...no success
  6. there is an orange one "use lsd oil only"..jacking it up and spin one wheel they rotate on opposite..
  7. same thing happened to my terrano's MC, replaced it with an aftermarket one with no mystery hole also, until now been wondering what the purpose of it. nice post.
  8. is your temp gauge giving you the right/true value? try installing another type of temp indicator to confirm.
  9. 2/3- located/installed @ chassis near bell housing. just follow your clutch line from CM going down to your slave cylinder
  10. just installed one for my terrano wd21 so far it fits with no problem...it was made of LLDPE material (taiwan made), a template was also included as a guide for cutting holes in your fender. oh the only thing i dont like is the word NAVARA embossed on it..(plan of grinding it in the future)
  11. still own that terrano with td27 engine? i also got one
  12. thanks guys for all your inputs, appreciated much..ill just stick with my stock wheel & tire combo.
  13. Thanks for the inputs guys...a friend is selling his 15x10 rim for less but am currently running 235s.
  14. Can i put a 235x75x15 tire on a 15x10 rim? Any inputs will be appreciated much.
  15. this is what I did when engaging in 4by...parked then shift in 4l or 4h then go, while running slowly you can shift back to 2H hub is still locked, to unlock the hub I move backwards say 10M and this is the only time that your hub is unlocked or youre on a 2WD.
  16. thanks guys for the reply, am also thinking of having a negative offset rims instead of spacers but it would cost me a lot thus I came to the idea of spacer installation.. another thing my tach isn't functioning do you guys know where it is plug in the engine? my rig is terrano wd21, td 27NA, manual tranny. lots of thanks.
  17. any input on using 50mm wheel spacer? planning to purchase/install to be able to widen my rig's stance, am currently using 235 x 75 R15 mudstar MT tire and my rim is stock. thanks for any input.
