Easy104
Everything posted by Easy104
  1. 198,000 miles on my 2000 not quite sure if timing belt has ever been changed...
  2. Ok, you guys are awesome!
  3. Can anyone inform me on whether my air conditioning compressor clutch can be replaced? I think the bearings in it are bad because when its engaged i can see it wobbling.
  4. Soo... when i turn my steering wheel all the way either way, i get a very annoying belt squeel and sometimes i cant turn it all the way because it feels like there are bumps in it.. its hard to describe but when i turn it to full lock i can see my tires have like a jolting turn. Is this just the belt slipping and causing this or is it something bigger. Also because of my oil leak (i assume) the boots on the inner tie rods are cracked and split in two parts
  5. The misfire was fixed and that's probably why I have the cat problem
  6. I fell like my car doesn't have very much power..... I cant even get the tires to squeal! Is this normal or should I have more power than that? My SES light is on and it says P0420 Cat efficiency below threshold
  7. I just bought this viper remote start model: 5101. i have no idea how to go about installing this. Any help would be awesome. I would love to learn how to install this, if anyone is willing to help.
  8. Has anyone replaced the whole a/c compresser? I think i am needing a new one and the local shop i went to said it would be around $800 to replace with a new one. Is this right?
  9. Ok, looks like i found the problem. Its stupid that i didn't notice it before... The tow hitch receiver turn signal wires had gotten loose and landed on my muffler which melted them together.
  10. I dont think any severe collisions have happened, there was scrapes all down the right side fender flares and bumpers and a dent in the rear passenger side door. What im thinking is that because i went into the mountains, it was mostly washboard dirt road and it may have shook something loose. Also i used the hazards once to indicate i was turning and it blew that fuse too.
  11. Well now there is something wrong with my turn signals.... Small issue yes, annoying issue.. Also yes. But it keeps blowing the turn signal fuse and yesterday I used the hazards to tell people that I was trying to turn and those blew too. If I put a new turn signal fuse it will work once or twice and blow again. Any ideas?
  12. Ok, soo my check engine light keeps coming on and off and the catalytic converter efficiency bank 1 is what it is saying. but this last week it came on and i got it checked and it was random misfire. Could my cat be causing this or is this another bigger problem. It feels like it is really underpowered but that could be just me, its my first car. My MPG's are at around 12.5.
  13. Well i dont think the micro switches broke off because it still clicks when i push the button.
  14. Yeah i have put several different batteries in it. I remember that it would work sometimes when i first got my car back in april last year. But now it doesnt work at all. im thinking that i just need to buy a new remote and hopefully that should fix my problem.
  15. Nevermind i must have took the fuse out and misplaced it or something. but my keyless still doesnt work, any suggestions?
  16. soo i was trying to figure out why my keyless entry was not working. soo i thought y not check all my fuses, well i pulled them all individually to see if there were any blown ones. but there were none and my keyless entry still does not work. but now my air bag light is on, on my dash. do i need to just take the battery off the car for 30 minutes and let it reset?
  17. Hey I need some help, with a light question. I just bought a pair of these: http://www.amazon.com/gp/product/B0039H9LDS/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1 and im wondering if i can just mount them to my factory luggage rack. Would that be possible or do i need to buy/make a light bar to mount these too?
  18. The only thing that comes up is Cat Converter efficiency. I think it needs a good tune up.
  19. I get about 11 MPG's in mine. What could i do to make mine better?
  20. Well it turned out to be something really simple that i believe the dealership did. It turned out to be that the wires at the distributor were pulled out of their connectors and getting bad contact. Now my SES came back on and i got it scanned and it was P0420 which is catalytic converter efficiency. Should i even bother to do anything with this or would it cause harm to the car?
  21. Ok so when i got my pathfinder it came without a radio antenna so it doesnt get very good reception. Today i bought a little rubber antenna that i would like to put in the same place as the original antenna. How would i do this. Do i need to take off the plastic part off that is around the wheel?
  22. So I got it in the shop today and so far they diagnosed it as a computer problem. Does this sound right?
