12
SkiBumBrian last won the day on December 28 2015
SkiBumBrian had the most liked content!
About SkiBumBrian
- Birthday 04/22/1959
'91 Pathfinder 4x4 V6 Off-Road
46+
SE Offroad
1991
Gender
State of Jefferson
Country
11,464 profile views
SkiBumBrian's Achievements
NPORA Old-Timer (5/5)
154
Although mine is '91 I had the exact same symptoms. I found it to be a small vacuum hose on the back of the engine, center top. It had cracked at the end and fallen off. Trimmed it, plugged it back on the nipple, problem solved! Does sound like a vacuum leak somewhere....
Goodbye. I will no longer socially participate on this website. The enhanced mobile view BS. I have had enough. Only for technical information will I come back here. Too bad, I kinda liked this site.
Is there a way to keep my phone from making me go through the hassle of telling it every time that I want nothing to do with their "enhanced mobile view?". What a PITA......
~HELP!~ My Pathfinder caught fire & it's my only vehicle...
SkiBumBrian replied to RobynInOK's topic in General Forums
^^ I concur. Getting the parts at a pick-n-pull would be my avenue but I have the tools and enough knowledge to get it done, could probably walk out the door for 50-75 bucks. On the other hand, your mechanic is going to use new, guaranteed parts as Slart said. Just lock him down on a price if that is the way you are going to go. Don't let him nickel and dime you to death during the process. It seems he is being square with you so far, just remember that quote was for parts only, not his labor, etc. the bill could be pushing 1500 bucks before it is all over. -
Good going, Robyn! I am sure the only damage is the burnt components and should be fairly simple to rectify. Make sure he determines where the fire originated and see that the issue is solved. -
Robyn, better pictures would help locate the cause but probably a leak in the fuel rail somewhere. Replacing the torched parts will probably fix the issue but not cost effective at a shop and certainly not at the stealership. Hopefully a fellow forum member with mechanical abilities will chime in and give you a hand. Pick and Pull can be a great asset in times like these... Did you smell fuel at any time before it burnt? Usually a fuel rail leak will give you a faint gas smell at times, mine was only at start up and when the engine was cold was was leaking at the hose coupler. -
I stand corrected! I should have known that, replaced the distributor a few years back. It was actually a vacuum hose going to the throttle body. My new garage has no working lights yet so I couldn't actually trace it out until this morning. Here are a couple of pics to clarify.... Thank you for being so tactful! lol !
Had been running "not quite right" the last few times I drove it. Stalled coming to a stop sign a couple of times so I figured I better check it out. Some animal ( probably a cat or coon) had been in the engine compartment and broken the air cleaner off the cold air intake and pulled the hose off the canister for the vacuum advance. A bit of JB Weld and I bet she will be as good as new. Will know tomorrow after epoxy sets and I reinstall. Oh yeah, changed out front marker bulb that had been out for months.... Happy Memorial Day weekend everyone!
94 pathy a/c belt installation instruction
SkiBumBrian replied to 94Pilfinder's topic in 90-95 WD21 Pathfinders
Better view from under the truck..... -
Looked at it sitting in the garage. Summer weather is upon us here in NorCal and only drive when I have to haul something bigger than a backpack. 2 wheels, 50mpg, and wind in the face is how I roll.....
OMG! my voltage regulator is on the fritz
SkiBumBrian replied to SpecialWarr's topic in 90-95 WD21 Pathfinders
Sneaky! -
I would go ahead and replace the splice with some fuel rated hose and new clamps. Both should be rated for pressurized fuel system. At first it may seem impossible but push the hose far onto the left nipple and then slide it back over the right side. Don't forget the clamps before you put the hose on... (I wonder what makes me bring that up?)
Just a guess but maybe the idler pulley is seizing? Mine is getting a bit noisy and will need to be replaced soon.....
Nice revival of a 7 year old thread ! Like was said it will probably take someone proficient with a slim Jim or remove back seat for access.
Couldn't break the bead on my motorcycle rim to change a tube so I ran over the tire with the Pathfinder... Problem solved!
