DryBear
About DryBear
  • Birthday 09/13/1971
    1987 Nissan Pathfinder SE-V6 5-Speed Manual
    Rarely Go Off-Road
Contact Methods
  • Website URL
    http://
  • ICQ
DryBear's Achievements
NPORA Regular (2/5)
  1. Oh man, I didn't think these bolts would be such a pain to put back in - I was wrestling with getting the dern things back in for at least an hour and still don't have both bolts back in yet. Argh!
  2. How do you tell the difference between the two fans, if they are already out of the car?
  3. Thanks for the feedback - looks like I will go with the 31x10.5s to be safe.
  4. So my 87 I4 2 Door Pathfinder came with 30x9.50R15 tires mounted on 15x9.5" wheels. I thought that was an odd size to have on my Pathfinder, but there didn't seem to be any problems, except for wear. So I went to the local Big-O-Tires to get some new 30x9.50R15 tires, and the mechanic says that the 30x9.5 tires shouldn't fit on my 9.5" wheels, and should at most go on an 8" wide wheel. Obviously, I've got those size tires on my wheels, and they hold air fine, so Is this guy full of crap, or what? In any case should I stick to the 30 tires or go with a 31 size tire?
  5. Just a note: I never did like the location of the starter on the V6, as it sits just below the oil filter - I always make it a point to cover up the starter with an old plastic bag when I change the oil filter so that the old oil doesn't spill all over the starter
  6. Yet another Flowmaster 40, with 2.25" custom catback and stock exhaust manifold/cat piping: http://videos.streetfire.net/video/wm/8b58...8f500275d6a.htm
  7. One thing that could help spot where the leak is coming from is that florescent oil dye that shows up with a black light. You add it to your oil, run the engine, and use the black light to spot where the leak is coming from. Usually works well.
  8. Another thing to check is the oil pressure sensor - thats where mine was anyway.
  9. Hallelujah! My front grill has been hanging on by a pair of clips http://autobodyclips.com/index.php?Search=nissan
  10. Squires Turbo Systems has a universal kit that you might be able to work with: http://www.ststurbo.com/universal_system The main problem I would worry about is all that dirt getting onto/into the filter from down below - of course that's not much of an issue with a Vette that doesn't go offroad
  11. Both of my brake lights on my 87 are out. I checked the fuse and its still good - any other place to check? My next thought is to the switch on the brake pedal, but want to see if there are other things to look for. Thanks!
  12. Better than the stock location and getting oil all over the starter, though Plus it looks like there is some room to put a pie-pan under to catch the oil while changing.
  13. I noticed my PS fluid was leaking pretty badly and noticed there was a bit of a gap between the bottom of the steering box and the pitman arm: Is that normal to have that much of a gap? Either way, I guess I'll be looking for a replacement - are all the V6 WD21 steering boxes the same - for example, will a '95 fit on my '87?
  14. AWESOME! The pick-and-pull near me only has ancient fords and chevys
  15. I just use ramps j/k I actually found what I was looking for:
