Cwolf
Everything posted by Cwolf
  1. Most likely because as reverse gear has no synchro it's just a matter of aligning the teeth.
  2. http://www.kut-snake.com/ Got them from this fella. He lives not far from me and gets the made locally. They're not bad, pretty solid once mounted up. I had to modify mine to clear the 33's though. Should be able to get a 32x11.5 in without having to alter them.
  3. I installed a set of hid's into my terrano but they don't have the moving part. Overall impressed with them but low beam seems a little to bright. Meaning I needed to adjust the lights tilting them down to stop the blinding. Losing a bit of the high beams effective distance but still 100% on nissans idea of lighting.
  4. Cwolf
    TD27 vacumn
    What in particular where you after mate? I don't have a diagram but I can have a look at mine ('89 model) and see what goes where for you. Could even take pics and send em to you if you like. Cheers craig
  5. No probs mate glad I could help. Anymore questions feel free to ask. Maybe check out navara.asia forum too few guys done conversions on there.
  6. Ka24e out of a navara would be your easiest 4cyl petrol power up. I've got a d21 dual cab nav with one in it (330,000k's) and goes heaps better than my mates Z powered king cab which has had an engine rebuild with cam,weber and extractors. Pathfinder v6 is another option but a bit more involved in changing plus manual versions are hard to come by. Terrano td27t diesel is yet another and also a very involved transplant. I also have a terrano with the td27t and it Is definitely my preferred choice although I do still find the navara fun to drive. Hope this helps.
  7. Hi dean. Just had a look at the first link where the guy put the copper breather into the top cover of the weber. I have seen dgv webers with that breather from factory on a carb that came of a ford pinto 2ltr engine. Can't remember if it was off a cortina or an escort but I suspect most likely TE or TF cortina being later and probably having more emission controls and the vent was part of it. Don't know if this helps you or not. Cheers.
