IndianScout
Everything posted by IndianScout
  1. great idea, I didn't even think of that... I'll let you know later thanks
  2. I finally got around to installing my system in my `95 Pathfinder, I get it all hooked up and everything is working great. but when I push the radio back into it's hole in the dash below the ashtray, I immediately get alternator noise, pull it out of the hole and it completely quite is there a B+ wire or something running above or near where the radio mounts in, I've tried every known grounding method and went as far as RCA & power filters, they help a tiny bit as soon as I put in that first mounting screw there it is.. anyone run into this problem with your pathfinder?
  3. how much lift would you expect to get on a stock 95 and just cranked the bars and not reindex them?
  4. ahh ok thanks, I'm off to get some today, can't wait to get this thing raised up now my 235's will look funny LOL
  5. which springs should I get, I'll get them tomorrow and I cut off about 1.5"??
  6. hell yes please do, so I can get mine raised up before winter sets in
  7. how far did the cherokee springs take you up in the rear?
  8. I have a question, on my stock `95 Pathfinder it has the typical torsion sag, so I plan on buying new rear springs with 1½" lift then crank up the torsion to level it out, will I run into any problems doing this? Plus it will allow me to run a bigger tire with the lift.
  9. I have a question, on my stock `95 Pathfinder it has the typical torsion sag, so I plan on buying new rear springs with 1½" lift then crank up the torsion to level it out, will I run into any problems doing this? Plus it will allow me to run a bigger tire with the lift.
  10. oh man 5 mins here and already I've found useful info time to level my pathy tomorrow thanks
