Beatup96 last won the day on April 19 2015
Beatup96 had the most liked content!
1996 XE 4WD
Screwdriver Mechanic
45+
XE
1996
Gender
Connecticut
Country
3,807 profile views
Beatup96's Achievements
NPORA Veteran (3/5)
53
When my '96 had similar symptoms it was found to have a crack in the MAF sensor housing .
Do we need to upgrade Braking System with Oversized tires?
Beatup96 replied to gzagun's topic in 96-2004 R50 Pathfinders
I have the Power Stop kit from Rockauto on my '96 with 32" STT's , slotted rotors and pads come with the kit . I also had new calipers installed at the same time but only because the stock ones were going on 16 years old . There is a large difference over stock braking power and 15" wheels fit fine . -
I seem to remember someone here fitting 35"s with a 2" AC lift , there was lots of cutting involved IIRC .
I like it . Look's like my '96 and my '02 had a baby.....
Check the strut towers for rust , especially if you're in a state that uses salt or brine in winter . When you drive it , get it on a road where you can get it over 50 , if the rear end feels odd over bumps or other changes in the road surface , "twitchy" kinda describes it , it may need rear control arms (bushings really) . 3.3's , not sure what year's but definitely 96's , had issues with the exhaust manifolds cracking . If you see "smoke" it may be cracked or have been improperly replaced at some time . If all else is good the only deal breaker out of these for me would be rusty strut towers .
BC's PF fish/duck hunter and stress eliminator :)
Beatup96 replied to bctriple3's topic in 96-2004 R50 Pathfinders
Truck look nice ! Where's all the fish and ducks ? -
AC 2" coils + AC 1" front spacer , Bilstein 5100 shocks , KYB GR2 struts , 32x11.5x15 Cooper STT's on Pro Comp 15x8 steel wheels with 3.75" backspacing . Upper and lower rear control arm bushings were shot and replaced with poly bushings , didn't do anything for ride height but did wonders for the handling .
There isn't any option to use other than stock length struts as far as I know , shocks can be had that will offer more travel . I like the Bilstein 5100's in my '96 but don't know the actual part number . Someone did post it here not long ago though . Follow Steve's instructions and use the proper hardware and you should be a happy customer .
Not too long ago you forced Steve's hand and he had to post pics of how you used his spacers improperly . You took a simple application and monkeyed it up so bad that even a non mechanic such as myself could see a total lack of aptitude . You my friend , have been relegated to troll status , not to be trusted or believed .
There are several options for a lift , depends what you want for ride quality and pricing , Most can be "mix and match" , and will gain anywhere from 1" to 6" usually in 1" increments (as a general guide , every truck is a little different) . The higher you go the more expensive pretty much , Fleury's spacers are the best budget option that I see for up to 2" . There are about 3 choices in ride quality , stock , medium stiff , and STIFF (AC coils) . A friends kid had 20's on a '98 , I'm not sure of the width but I know he had to use wheel spacers and still had some rub . He had no lift and the wheel wells were filled up , I doubt there was much room for any flex off road . I can probably find out what sized tires it had but not until next week sometime . What sized tire you can fit on yours will depend on the offset of the wheels or size of spacers if used , and how much lift you do .
Thanks guys !
So I'm driving the "new" 2002 SE now , and one thing is a bit of a PITA . The drivers side front window has the "auto" thing where it will go all the way down or up on it's own depending on how you actuate the switch , as does my '96 . Problem is that the 2002 most often will go all the way up , but then opens itself again about 4" . This is a very sparsely optioned SE and doesn't appear to have any memory options as I can tell . Is it something replacing the regulator might fix ? Don't want to buy the part if it may be something else . My '96 never did this .
A Hardbody at heart with a V8 and a Eclipse body . https://www.yahoo.com/autos/s/zombie-problems-craigslist-mitsubishi-4-4-answer-203037404.html Someone has quite the imagination !
Yeah , I leave for work in the dark and come home in the dark this time of year . For the short term I think I'll look for a cheapo stick on light . Made it through DMV in 2 hours , a record ! Took a better look at the tires and got the heebie jeebies seeing how dry rotted they were , went and had 4 new 255/70/16 Fuzion SUV's put on . They're "cheap" but they may not be on long , they seem decent for the money and get pretty good reviews . Tire guy says the front wheel bearings are a little loose and the shocks are leaking , good to know and they were things I was going to have gone through anyway . My target was to find a 3.5 in decent shape for $5000.00 , I'm into this one for $3200.00 with the tires so it's looking pretty good .
I'm not really sure yet what I'm going to do . I can't even utter the words yet to say what made me do it , when I get the 2002 registered and on the road I'll take a pic of the '96 . I'm a bit superstitious and I still need it to get me to and from the DMV . I may swap a lot of parts and there wouldn't be much left other than a decent motor and tranny , it would need a trailer to take it away . Most of the suspension , aftermarket brakes , tire carrier and latches , plate holder/light , full set of tray style mats , wheels/tires , etc..., would be kept . I'm also considering keeping the 2002 pretty stock and making the '96 a deer hauler on a friends farm .The CT state record buck was taken on an adjoining property , we goose hunt it , and it'll be long gone before his twins are old enough to get their paws on it... I need to get an opinion and a quote on the '96 before I decide , but it will definitely never be a daily driver again , and if I handed over the title to someone I could not in good conscience mark it as anything but junk/salvage . I can only think of one person I've ever met in 54 years who I'd hand over the keys and say "Drives great ! Go do 80 on I-84 !"...
