passengerpete
Everything posted by passengerpete
tx10 swap with tx12 possible?
passengerpete replied to 12A's topic in Solid Axle Swaps, Hardcore Custom Fab
ya can run a tx12 behind the auto with a few mods not much tho. I used the hole patrol gearbox in mine lots of messing about tho -
nissan terrano 92 turbo diesel sas help
passengerpete replied to jayhedges's topic in Solid Axle Swaps, Hardcore Custom Fab
I used Nissan gq patrol axles as had then sitting around. just mod a tx12 to ya auto. -
if ya going to sas it mate how much can ya do your self ? because paying for some custom fab is not cheep. may cost $ 3000-4000 I did mine cost $800 -
Rear Bumper/Tire Swing pics for WD21
passengerpete replied to Jacob211's topic in Solid Axle Swaps, Hardcore Custom Fab
its a rubber moulding that's screwed or pop riveted on . ya buy it off a roll by the meter. $50nz. dose the hole truck it comes in 50mm or 75mm wide cheers. -
only 33'' soon to be 35'' cheers -
na mate ya wont need to, ya intercooler is only cooling the air, but by turning up the fuel and boost then get it tuned the old girl will take off. I run mine on 18psi for four years no problems
I go two on mine -
its about a 1992. there are two types for the same shape the Early one 1989 ish had more curved shape and the face lift 1992 ish was squired off.
and it works really well. on the motorway the the temp gauge sits lower then it use to, the vent sits above and slightly back of radiator. my theory on why its works is that the air going over the vent is high pressure, and the hot air rising out of the vent is low pressure thus creating a vacuum sucking the hot air out. i could be wrong but what eva is going on has definitely lowed the engine bay temps.
i put a Subaru scoop on backwards for my vent.
sure
sure no problem.
cheers.
thanks mate and yes tyres are km2s and custom bumper/winch mount
truck finished yay
wd21 sas, what axle options ?
passengerpete replied to Stinka's topic in Solid Axle Swaps, Hardcore Custom Fab
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=27407 i have a build page on anouther site, -
hi mate the y60 is about 100mm to wide , but i did not bother shorten them. i will just buy some -offset rims to bring the track back in, don't forget you will need to change ya transfer case around to the other side. Meany ways of doing this. i just used the safari gearbox as well, just so i could use a mechanical winch. -
yea it works. i have done it to my one. -
i prefer the full chassis of the wd21 and the shape is to my liken more.
go patrol to keep all nissan. front and rear ratio both the same.
