nckrawler
Everything posted by nckrawler
nckrawler replied to fleurys's topic in R50 FAQ's & Pinned Topics
I'm not sure the backspacing but they are factory 2002 4runner sport wheels. Where in nc are you? -
I think their bumpers are ugly. They made it cover our enormous wiper fluid reservoir so instead of relocating it and having a sleeker bumper you get one with no approach angle. Thing looks like a plow
I wheel in the mountains so I don't want tons of llift making it top heavy the lower I can be the better I feel but want the biggest tires I can fit which I'm assuming would be the 35's. I put 37's on it and that's what I was going to run but I figured I would be putting hub bearings in it every other day.
And thanks for the compliments I've been slowly building it for 3 years now and it's finally coming together -
The tire carrier came of the pre face lift r50 so it fit perfect I snagged it up at a u-pull it yard. No my pathfinder was originally white but I wrecked it and when I rebuilt it I ended up with a junkyard door the was maroon. As far as the build goes I need more info on power steering pumps mine capped out wheeling with big tires so I've been looking into an agr high performance pump. I also need gears a locker and sleeve my tierods. -
I'm not really a flexy guy. I believe in low center of gravity, bump stops and droop. Waiting now for gears and an agr power steering pump as bigger tires and high miles has destroyed my factory pump thing squeals like a pig upon startup
here she is with 37's and here are some clearance pix with the 35's -
2 inch wheel spacers, a custom front bumper, cut the bottom of the fenders in front of the doors, & relocated my wiper reservoir. Used a Honda overflow tank mounted in the engine bay -
I've actually got a sheet of aluminum 1/4" thick that is going on this weekend so the middle will have a skid
Sorry for not.responding it's just such a pita to upload pix here I've since built a bumper added a snorkel and running 35's
35 inch baja claws. 2 inch lift -
<a href="http://s1072.photobucket.com/user/nckrawler1/media/20141102_134944.jpg.html"target="_blank"><img src="http://i1072.photobucket.com/albums/w379/nckrawler1/20141102_134944.jpg" border="0" alt=" photo 20141102_134944.jpg"/></a> -
The final word on lifting the R50 at a low Cost
nckrawler replied to fleurys's topic in 96-2004 R50 Pathfinders
Those front spacers are identical to the ones i had CNCed for my truck about 2 years ago mine measure 2.25" im glad somebody is now offering them for sale they work great -
not sure if anybody has thought of it but i have 2.5 inch spacers up front and stock springs im doing sfd but since the spring bucket has clearance issues i was gonna do the 4 inches on the bottom where the spindle connects to the strut thus giving me 4 inches more of tire clearance and lift any insite or thoughts would be appreciated
whats the cost for this i looked up that part and it was over $400
is there a specific reason for using the expensive coilover or could an axle be setup the same as jeep cherokee front axles with spring buckets and seperate shocks?
been toying around the idea of putting a cummins 4bt in my pathfinder with the tranny, t-case, and axles from a k5 blazer with 37's didnt know if anybody had tried a diesel swap or had any thoughts
i cut those as well and moved the screw up from "factory" bottom to the "new" bottom of the fender i just wanted to eliminate the reverse scrubbing
sorry it took so long i didnt see the comment asking for the pic these are just the steel low option titan wheels but i worked at a salvage yard and the tires were new and free to me so i got them but they are 17's so i had to use the rim lug pattern is the same hub was way to small..................here they are on my truck so it should be proof of lug fitment
you sure cuz i also have a set of 01 xterra wheels that i ran before i got my titan wheels if they were gonna change it i wld imagine they would have done it when they changed hub size but mine fit minus hub dont know y any other models would be diff
the bolt pattern is the same however i have 07 titan wheels on my 2000 pathy and the hub size(center hole) was smaller i had to bore them out to fit im not sure when the hub size changed but i think it was at the end of 04 when the new body styles came out i could be wrong on when exactly the hub size was changed but im almost positive those wheels wont fit without being bored out unless the xterra hub never change but i know the frontier did so im assuming the xterra did also
^^^^^^ hahahahahahahaha thats what i asked
