Everything posted by nispath4wds
Thanks. I also thought, maybe I should change my t-case fluid. I have never done it before, god knows what is the quality of it. I read it could be helpfull, in my case.
What about a cabin 4x4 lewer, maybe is not turning off completly. Transfer case, maybe thats my problem. I'll take a look on weekend, and see what I can find
I have KYB GR2 struts and shocks, 2" lift, Nx4 1" strut spacers in front, 31x10.5x15, Mile Mikers manual hubs. You think this is something serious, or some parts I should upgrade? Flange, where is it located?
So in this case, my problem must be with front shaft. What i think is that after switching from 4x4, inside the cabin the front drive shaft is not completly unlocking the differental. Maybe all I need is some grese. What you guys think?
179 km/ 111 miles so far, motor and trans runs well. Hope it last for long
I just wanted to add, that I never had this problem before changing the lift and wheels.
So what kind of hubs do I have? I bought Mile Makers Hubs with locking and unlocking mechanism in front.I am asking this question because I've been having some problems with these hubs since I started using 4x4. Let me explain: With my hubs locked in, and 4x4 liver disengaged, when starting to accelerate 40km/hr my track starts to vibrate, it also feels like 4x4 is engaged even the green light is off. I dont seem to have this problem with hubs locked in and 4x4 engaged. When I unlock the hubs there is no problem with driving, everything works well. I just changed the cv boot, and checked U joints. Any ideas??
So what kind of hubs do I have? I bought Mile Makers Hubs with locking and unlocking mechanism in front.I am asking this question because I've been having some problems with these hubs since I started using 4x4. Let me explain: With my hubs locked in, and 4x4 liver disengaged, when starting to accelerate 40km/hr my track starts to vibrate, it also feels like 4x4 is engaged even the green light is off. I dont seem to have this problem with hubs locked in and 4x4 engaged. When I unlock the hubs there is no problem with driving, everything works well. Any ideas??
97 Pathfinder LE remote start install
nispath4wds replied to 12161216's topic in 96-2004 R50 Pathfinders
Is this true that you need a "car key chip" to install a prostart remote starter in 2000 pathfinder? Meaning, one key for ignition, second key for remote starter. -
Yes its 4x4 shifter. I am leaving it today at mechanic so they can grind of my calipers a little bit. I found out, the side that is making the grinding noise caliper touching wheel a little bit. I hope this is the answer to my problem.
So, there is no aligning with any marks. Out of the box , just put it on.
Front right tire vibrating sporatically
nispath4wds replied to jwbehm's topic in 96-2004 R50 Pathfinders
I have a simular problem happening since I started using my manual hubs. My left front wheel starts making banging noise when I start fast from the intersaction. It only happens with my hubs locked. A 2 months ago I instolled my new struts, new cv boots and did an alighment. I realize that my left wheel is very close to caliper. Could this cause the problem? -
I have MM hubs. Is this a problem or they just work this way on 2000 pathfinder.
Should there be a marc, in what way to instal the hubs on to the wheel or it doesnt mather how you put it on?
Yes the light goes off
Is there a specific way , to install manual hubs to work properly on my vehicle. Let me explain my problem. The other day i tried my hubs finally. I locked them in, engaged 4wd inside the cabin. It works great. I then disengaged 4wd inside the cabin, and when I drive I feel like 4wd is still on. What could be the problem? Is there an explanation for that?
I can't believe. They finally came up with one. About 2 years ago, I was assembling a rc crawler and I wanted to use pathfinder top. I searched internet, couldnt find in anywhere. After all I used ford bronco.
Vibration in 4 wheel drive shaft
nispath4wds replied to nispath4wds's topic in 96-2004 R50 Pathfinders
Sorry guys, I looked into nissan book. What I ment is 4x4 shift inside the cabin. It has a little vibration when the motor is on in parking gear. When I apply gas i feel more vibration and granding inside. -
Does anybody has this vibration in 4 wheel drive shaft? Since I bought my truck , have a light vibration , I wonder is it normal or some adjustments has to be done.
Yesterday, I had a similar experience on my vehicle, vibration when I pulled out from the intersection. I was thinking to fix it on Monday. I need to do some shopping today. Can I go on the highway? How much does it usually cost?
I find out its illegal to use tire studs in GTA. I just wonder should I lock my hubs when driving in icy road or plane 4x4 is good enough.
So ,how was the winter driving on F/Destination tires?
My truck came with all season,cooper discover H/Ts, and with 4x4 engaged, I didnt have much trouble driving thru snow and ice. I will see how I'll do on current tires for now. Thanks for the tips.
I was wondering, have anyone used before tire studs? I upgraded my pathy with F/Destination M/T and from reviews I've read, I should take it easy on ice. Is it worth it, to put them on. How u guys see it?
