So, I have no dash lights in my pathfinder (never had them since I bought it).
I've done some searching, and its NOT the following:
Bulbs - I recently fixed the instrument cluster voltage regulator and checked the bulbs when I had the instrument cluster out, both lit up fine with a 9v.
Fuses - I've checked all these. Also, other things on the same(?) fuse work - taillight etc.
Specifically- All my instrument lights work (e-brake, turn signals, 4x4, brights, etc.) Its just the tach/speedo lights that don't come on. Also the in-dash brake indicator doesn't light up... But the actual tail lights do light up. After some searching I'm wondering if my dimmer switch is bad? I pulled it out and looked at it and cleaned it with no luck.
So I have two questions:
1- Does this sound like the dimmer switch?
2- I've read you can just bypass it to get the dash lights back (as a temp solution while looking for a replacement). Anyone know which wires to connect to do this? I saw a Black, A Pink/Black, and two Pink/Blues running into the dimmer. I'm scared to just cross two wires w/o being sure...
Any help would be appreciated!
