accurrate1
    2002 LE
    Rarely Go Off-Road
    New York, NY
accurrate1's Achievements
  1. Installed gas hood struts, loose prop stick ...
  2. Great news!!! Couple questions; Where did you get the 1/4" spacer and Rugged Ridge 15001.61 hubs? Please do post couple pics with the spacer, wheels and the hub installed. I was going to install warn hubs on my 2002 LE with no sucessed due to the center whole of wheel where too small, and now you give me holp!!!
  3. Hi Bruce, what part of Taiwan you at? I'm from Taipei, now located in New York! Good to see you!!!
  4. My ride was 02 LE, was tried to install worn hub but the center of the wheel was too small. You need to either bore it out or get new rims.
  5. Has any one run those trailing arms? How's the performance compare to the stock arms?
  6. I run Bridgestone Dueler A/T Revo, that might be the promble, and what you mean by "NVH"? I was thinking about that too, the sound could be caused by the "tires and transmitted from the axle through the harder control arm bushings", so I let some air out of the tires. it does help a bit but not a lot.
  7. I don't know if they grease those bushings when install on my truck, will that be a problem if is not been grease?
  8. Is not low-pitched sound because I just have my u-joints replaced, more like "doomm" sound from the back of the truck like some one with cheap AMP and speakers and when speed up to 60 or hit small bumps. I an thinking could be the combination of kyb shocks and bushings? The sound just making me nuts!!!
  9. I was in dealer few weeks ago, the service manager called me and show me the both upper and lower control arms needs to be replace. He quote me $1,100 and offer me %10 discount for only $990 (he said) in total, I told him "NO THANKS!"and drove away. I then ordered thsoe bushings from 4x4parts and some kyb shocks have local guy installed for me. I was very happe with the proformerce but I notes the whole back end become stiff and doomm sound come from the back of inside the truck make me crazy. I try to let out some air on the real tires from 35 to 32psi to soft the real a bit, it helps but not a lot. Has any one installed those bushings experince the some thing? I'm seriously thinking change back to the factory control arms!!! Thanks!
