Chicano2005
About Chicano2005
  • Birthday 09/24/1988
    1999 LE Canadian
    Screwdriver Mechanic
    Do Not Go Off-Road
    Chicago
    Mexico
Chicano2005's Achievements
NPORA Regular (2/5)
  1. Thanks man...yeah I remember that converter before. Hopefully I find some tires soon. But I was thinking maybe wait a month, save some more money and buy them during the 4th of July specials. I still have to buy the city sticker which is $150 total. Sent from my HTC One V using Tapatalk 2
  2. hey guys im asking for some suggestion as to what tire size i should get. im tight on money!! the oe size is obviously 255/65r16 but im having trouble finding them for a reasonable price to me. ive calcuated sears price and its a fairly good price to me under 500 all 4, installed. but i was wondering just in case what other size i can put on without changing the MPH or the odometer. any opinion or suggestion is welcomed. P.S. i searched for tires but all threads came back for off-road tires and tires for a lifted pathy. mine is all stock. Not looking for off road, im looking for regular city tires.
  3. bolt pattern is 6x139.7 same as 6x5.5 96-99 i belive will fit 15inche rims 99.5+ you need 16inch and above EDIT: center bore is 100mm other nissan trucks/suvs above '04 changed to 6x114
  4. towncivilian- no i have not changed the trans oil. you recomend i should? if so which type? thanks for your response!!
  5. im getting annoyed by the 2nd gear (auto) shifting semi-hard at around 3-4k rpms below or above rpm's is less noticeable sometimes shifts perfectly. i bought the pathy like this 2 years ago...so i dont think transmission is going out! will a simple drain/flush refill, maybe synthetic oil help?? any suggestion/comments are appreciated!! 99.5 LE 4x4 AUTO Canadian
  6. Well, the steering wheel stoped shaking completely. I cant fell the pathy shaking/wobbling but yes i will be on the lookout for another rim or set of rims on CL.
  7. Finally got it fixed!! Turns out to be a bent rim. So i just put the rear ones to the front. Thanks guys!!
  8. well, i did the balancing and it did not help. i will take it for a check-up to a local mechanic maybe they can figure it out.
  9. So any of you had the same thing? If so, what did you do to fix it?? It shakes side to sie under normal driving, slow or fast. My guess is a tire may have a bump somewhere.
  10. So i bought these frontier oe rims but they dont fit, necessarily. You'll need spacers at the front maybe rear, and in my case, extended wheel studs. Now to sell them on my local craigslists. I thought ill let you all know. http://carphotos.cardomain.com/ride_images/3/576/4521/26439760012_large.jpg 99.5 pathy It doesn't let me insert image so i just posted the link.
  11. frontier wheels; to mount or to trade??
  12. looking for 99.5+ center caps
  13. looking for a 99.5 LE center cap! six spoke rims (3 fat 3 skinny)
    1. Show previous comments  1 more
    2. DantheMayun
    3. nismothunder
      nismothunder
      Make sure they fit your front hubs before laying any money down.
    4. nunya
      nunya
      gotta bore the hubs out to fit
  14. has anyone opened the fog light housing? water is inside of 1 of my fogs.
    1. Show previous comments  3 more
    2. Chicano2005
      Chicano2005
      I got all the water off but it has a little dirt inside. My previous car has oem fogs. I opened them using a heat gun but it didn't work on these fogs.
    3. NissanNismoZ
      NissanNismoZ
      spray the insides out, let them dry then put them back on? :)
    4. Chicano2005
      Chicano2005
      youre right! now that i remember i have keyboard duster spray. i will use it to blow if out! thanks guys
