Everything posted by TheDirtyFresh
I ordered headers for mine online, then grabbed a magnaflow cat and muffler. I took it to a shop and had them just fab up new pipes to replace everything.
What color is your Pathfinder?
TheDirtyFresh replied to TeenZombie's topic in 90-95 WD21 Pathfinders
OD & Black -
Adding a turbo/intercooler to my '95 Pathfinder
TheDirtyFresh replied to 2milehi's topic in 90-95 WD21 Pathfinders
I'm curious how you determined which wires ran from where on the MS board to each pin on the ecu connector. Were there instructions for that with the megasquirt? Amazing build! -
Gear sticking until restart
TheDirtyFresh replied to TheDirtyFresh's topic in 90-95 WD21 Pathfinders
Fluid is at proper level and I changed it recently. I've tried toggling the overdrive switch on and off when it sticks to no avail. I've had the battery in and out a couple of times when welding and such so I would think that would've cleared any memory. Thanks for the suggestions though! -
Bummmmpity bump! -
So, sometimes while driving my pathfinder (auto) the transmission will hold a gear until I turn the truck off then turn it back on. After that it'll be normal as long as I'm driving it. I thought for sure my transmission was toast, but now I'm starting to suspect the TPS or transmission computer? Do these rigs have a separate ecu for the transmission? Does this sound like an issue anyone else has had? Thanks!
The body lift wasn't complicated, just some elbow grease required for the steering shaft and making sure you don't snap any bolts off. In other news, I have my exhaust on and I couldn't be happier. The only difference at idle is tone not volume, but when you're in the throttle it sounds rowdy! I'll get a YouTube clip up asap for you guys.
Nice!! that should be everything I need, I'll let you know how it goes!
I'm thinking about picking up a remote starter before winter sets in, has anyone installed one of these themselves? I wouldn't think it would be overly complicated but I've been wrong before.
This thread has perfect timing, I just managed to shear mine off the other day!
The exhaust on pathfinders is pretty simple really, it's a bunch of pretty straight pipes with the only bendy section from the muffler over the axle. My local shops quoted me less than $100 to bend a 2-1/4" pipe. That combined with a magnaflow cat and muffler from ebay I'm in for less than $300. On a side note, new rad in, and my wires from 4x4parts showed up so I can get those in tonight!
This one shows the lift a bit better because of the lighting,
New rad en route!
So I have my body lift on, and I didn't think to rotate the upper rad hose, so it put pressure on the plastic inlet there. Pressure + plastic = broken inlet, has anyone repaired this with any luck or should I just order a new rad?
I know people who have used this on car floors after repairing them and from what I've seen it's pretty awesome stuff. We don't have the most hospitable climate to cars here on the east coast, and the cars I've seen with that have been pretty mint.
When I called Accel the person said the 8881's wouldn't fit my truck either. I've been doing more digging, and if I come up with anything I'll post up!
Well shoot, I called Accel and you're right these wires are for the older trucks. I checked out wires on 4x4parts.com and I guess I'll just get them from there, I couldn't find annnything from the other dealers. Lesson learned! haha now, anyone want to buy a barely used set of 8.8mm wires?
So, I ordered plug wires since I put the msd box in, and some sites say that the Accel part number 8883 is for 3.0 v6 pathfinders, but now that I have them in hand they don't seem proper. Some of the ends have the 90 degree bends and others are the vertical ones. There also seem to be wires that are too short / not fitting. Now doing more searching and some sites show the Accel part number for the pathfinder should be 8881 instead. Has anyone ever used either sets of these wires?
About time for an update!! Since my last post I've: Installed a quest alternator! thanks for the write ups! installed the msd! once again thanks! had my mechanic install the new centerlink / steering stabilizer / idler arm brace. What I have left to do for this batch of mods is: Install body lift and headers / exhaust system. My mod money got a little set back when I had to pay to get my car out of impound
Ahh yeah I was super pleased about that part, $230ish for a centerlink, plus the ebrake cables I was a really happy camper. Anyone know off hand what size the maf is on these things so I can find a proper adapter plate for my new intake?
I just got my rig back from being freshly inspected, new idler arm brace on and steering stabilizer good to go as well! This weekend I'll get time to rig up the msd unit and the k&n apollo I picked up as well. What a nightmare it was to find e-brake cables for this thing!! I ended up having to get them directly from Nissan at $120 / side!
More fun!
Suspension Lift Kit vs JGC Springs
This was the first time I've been hit by USPS, it's just frustrating really. -
I just read that part! I'll check it out, a friend of mine works for Canadian tire who carry Rancho gear, so I can get him to pick it up for me with his employee discount
