Everything posted by pathyboy12
It works alright..... mostly just a monitor....
I'm changing the rotors to so I had to any ways... and that's what I figured but I didn't know... also putting manual hubs on... but thanks for the clarification guys!
Changing both Cv axles. And putin warn manual hubs on. Got the rotors and hub assembly off, but not sure on were to go now... do I have to unbolt the strut tower? Or take anything else off? A diagram would be much appreciated!
Premium vs. Regular Fuel: THE ANSWER
pathyboy12 replied to Matt4949's topic in 96-2004 R50 Pathfinders
just wondering... but i have a 96' 3.3 and it says use 87oct, and most of the gas stations round here have regular at 85oct and then 87oct with 10%ethanol then the premium 97oct. i normal put regular 85 or should i use the 87 ethanol? -
finally got my lift and tires on
pathyboy12 replied to pathyboy12's topic in 96-2004 R50 Pathfinders
no, no rubbing at all... i choose tires that i could flex in and everything. i went with 15 cause i couldnt find any 16 with the right BS, i was first gonna get 16x10 and 265/75/r16, but to complicated to find right specs and all... then i went 15x8 and 31/10.5/r15, i really like the pro comp rock crawler series.. solid wheel, good price and look great -
1)3.75 2)i wanted room to flex and move more, dont like cramming tires 3)yes sir, minus the strut mounts, wheels, tires, and air filter 4)they fit perfectly, imo -
thank ya thank ya -
do you happen to know the measurements of the VG33E? cause we did a rough measurement and came up with 27ish for the lenght, and the 350 is 28. and thats minus the bell housing, fan and radiator
so you think i should go FI instead of carburated? i thought carburated would be better? i know on romping around and on a steep hill it might starve it like you said but theres older trucks that people 4x4 in all the time, would it really cause that big of a problem? the guy thats helping me has an 81 ford step sid, holly 650 double pumper, and he goes nuts with that thing, no problem
dang BowTied, thats exactly what i needed.... thanks. yeah me and my friend were looking at it and we were gona make a coustome hood. and we didint know if we should go custome on the manifolds or no? and we figured the fact that it doesnt have all that fuel injected stuff in her, that that'd save some space as well
Yeah, I have most of it figured out... everything will fit and match up. Only thing is with the bigger radiator and extra cylinders Idk if the engine bay is long enough.... I know It's not wide enough, and I'm gona have to cut a little bit... also would it be deep enough?
yeah, im leanin twords the 350.... i have a garage full of tools and such. and a guy who has rebuilt a couple of chevys. i do plan on keepin the pathy for as long as i can, not gona sell it, run it till i dont have any money to fix her. i know itll be coastly and take a while but then ill have one unique pathy with some power....
I thought about that but Idk... I have a friend who put a 350 in his jeep, and all the stuff you can add and do with that motor is pretty crazy
Why won't I?
It's all gummed up, and on last leg.... has a lil over 200,000. Plus I want a lil more power
I was thinking about buying a Chevy with a 350 and manual transmission, then swap it into a pathy. And SAS. duel carb, forged piston, crank, cams. Whole nine yards. Or rebuild my pathy motor? Maybe bore and stroke. Forged piston, crank, cam. Everything What's your guys thoughts?
thanks! yeah its the ONLY pathfinder with any modifications in my town that i or any of my friends have seen... all we have is flippin jeeps -
it depends how bad your shocks are, couldnt hurt. i put the KYB struts on with the OEM strut mounts and it does just fine, but if your not paying attention to spped pumps and you hit em to fast your struts top out and make an amazingly awsome sound it also depends on the stock struts if there used? and how much there already sagging and worn. btw nice lookin pathy, me and a friend are making one here soon -
Thanks, its about 2.5in AC lift with KYB and bilstern struts and shocks. i didnt use strut spacers but might get some when i put my front bumper on. i didnt do the hubs yet cause of weather, but plan on doing those as soon as possible . and if your looking for anymore info this forum has a truck load of information about lifting r50's pretty much every question you have it has an answer for. thanks, i looked in a haynes manual and figured it out on friday -
it shows fuel efficancy, throttel position, battery voltage and mass air flow. it shows it in percent form, bar graph form and line graph form. like i said i didnt plug it into my O2 sensor, but you can also do that... it didnt change fule efficancy, all i noticed was that it took off a bit faster and a little more responsive, not much but a little. one down fall to it is if the modual gets unplugged then the truck dies completly, then when you plug it back in, the MAF/MAP sensore code is tripped but it goes away after about ten or so starts. i found an alternate way also... im sure you guys have heard about it but you can send your ECU in and the'll alter it and change the stock settings. could find an ECU at a junk yard while yours is sent in. just an idea -
thanks! -
the jet v-force is pretty much a modual but when i put it in she seamed a little bit more jumpy. it plugs into your MAF/MAP and your throttle sensor, you can also plug it into your o2 sensor but i havent done that yet... all in all i think its worth it but thats just me. -
ya, thanks everybody it probably wouldnt have happened without some of your guys's help! -
thank ya thank ya -
i went through about 5in of snow on a back road and they did great!
