88_Pathy
    Oversized tires and protection
88_Pathy's Achievements
NPORA Veteran (3/5)
  1. Mine sounded like a mad weedeater above 3500rpm with a test pipe and a magnaflow. So I just bought a high flow cat.
  2. I have dual batteries with one walmart special 1000cca and a orbital red top. They will run my winch at an idle no problem and barely bog the truck. Stereo no problems either. I like the red top orbitals they are similar to the yellow optima i think.
  3. They don't get louder but it will eventually rust. They have a plate design inside not packing. I liked how mine sounded.
  4. Thanks. Thats enough info.
  5. Does anybody know the diameter and spline count on the shaft. Thanks
  6. Sweet, how about the heat off of the turbo in the engine bay behind the headlight.
  7. Good call on the daul cases. I have looked into a adapter to do a toyota case to my trans and it is promising. Damn that thing is huge.
  8. Is there any pics of your progress? Sounds sweet.
  9. Bad ass rig. T- case gears are in the future I presume.
  10. I would not straight pipe it. I did a test pipe on mine with a magnaflow and it was gross, like a beefy Honda. 40 series Flow sounded a lot better but still ricey.
  11. We planned a rear mount and were going to use a 2 or 3 quart tank with a small electric oil pump to circulate the oil. The only thing I was concerned about is the air filter location. Also the thing with a turbo in the engine bay is heat and room. Then the California smog nazis would hate that set up. How much boost and price estimation are we looking at cause my rig is a snail and I need power.
  12. What about a rear mount set up. Or a set up for a TBI system.
  13. Just do it yourself. It is not that hard and if it breaks, and it will, just fix it.
  14. Your Divorced t-case is sick but why a 720 case? Why not a Toyota with a 4.7 gear or something. Your fab looks great.
