IpathyXe
Everything posted by IpathyXe
well i flushed it then refilled it opend the radiator cap while it was running to let some of the coolent cycle yet i refilled it with only water possibly my problem
Alright just flushed the ratiater... took it for a spin and it over heats worse then ever... Mostlikley the thermostat... Soo i had the thermostat changed last year, but i had it done for free soo i dont know how much it costs or if i can do it at home without having pull the engine out of my car.. help anyone???
Yeah I want to change to standard also...
yeah this hasnt happend until now thats its begining to warm up but im now looking for the drain plug on the pathfinder where is it?
oh also i had the thermostat replaced july last year if it makes a difference
So today i was driving to Fort Collins and I noticed that the temp guage in the car was higher then normal when i came to stop the temprature shot straight up... After i got the pathy to about 3000 rpm it went back to normal, i also noticed that my mpg seemed to drop... help!!! i have a big camping trip this weekend and this needs a fixin!!
So does any one know how i can decrees cabin noise, from the engine and from outside road noise, my current tires are AT tires and are desently quiet but my engine is loud.. any sudgestions?
IM just curious when does the low gas light come on because I've gotten it low, and it has never come on. Maybe soemthings wrong?
Alright cool just making sure.
If you have done an alternator swap I'd like to know how difficult it is and wether I should just take it in to the shop to get it done. I preferibly would like to do it myself ( good thing to know) plus i have the Haynes book soo.. just give me some feed back.. you guys rock!
Hi i have a 93 pathfinder in working condition i could sell it to you but i want 800-900 dollars for it. It has a manifold leak, trasmition acts strange sometimes, also the front suspension needs some work, yet its done me good but right now theres more problems i can handle. so if yor interested call or email me at caseymeyer183@hotmail.com or 1-361-815-6679.
How about that snow man the pathy's love it and 2 more feet on the way. I'm also looking for some new corner lights on broke due too a wreckless old lady in a caddy. I was cool about it figured light cost less then going through the insurance company...
so i've got a little extra money in my pocket enough for some thorely's but how much does it cost to put them on? also something to keep in mind is my studs are broken? anyone?
So i was looking under my pathy the other day and noticed the torsion bars had some bolts conected to the frame, long bolts I might add so is there some sort of setting for different terrain or ride quality?
your bearings need to be repacked but should not cost much money if you have some stands and bearing grease you could do this at home. very easey and simple procedure.
Mine burns at a stop though i can smell it. espicially when i park in the garage
I have a proffesor at my college that worked for nissan, his words (made an assload of money off those pathfinders RMS is 80% of the time the coprate, ) mine leaks to.
under 35 psi can pop the seal from the tire if you hit your side wall, So watch out for flats Unless you have beadlocks
Yeah mud caked in the wheel or if you hit an object just the right way, it might a weight off the wheel.
M,kay I'm completley stupid i put on new pads and went for a test drive, and guess what didnt bleed the breaks... So i sat around for an hour thinking i did something wrong..
alright I was just think of all the fun i could have with a megaphone on my pathy, so i was thinking does anyone know where i could get one?
alright i think i found the problem alright I think theres too much brake fluid in the system causing rubbing with the rotors
Thanxs, you guys are life savers
Alright so for a while now maybe two weeks my brakes have been squeaking alot and have started to make a loud scraping noise while the brakes are being engaged, so anyways when i got home i decided i was going to take the wheels off and givit a look. as soon as i pull out the impact wrench i rememberd i need the key for the lugs well guess what, cant find it. Any ideas?
Alright its time to change out the distributor and plugs but who makes the best, whick type of plug should I get, quad pronge or regular? Give me some info
