WRL69
Everything posted by WRL69
  1. When does install BKR5EY or BKR6EY or BKR7EY sparks plugs? How define if is required Standar Type or Cold Type or Hot Type? What spark plugs have to install in my 93' SEV6 VG30E? To select them is important the enviroment temp.? Regards,
  2. What "exhaust of the control unit" ? Regards,
  3. Could you attach pic where I can look that heat shield? My mech tell me is all good ? Regards,
  4. Has anyone any idea why that ABS Control Unit turns hot, very hot?
  5. Hello. What is the device under driver seat in my 93' SEV6 A/T? After I driving 30 mnutes it turns hot.
  6. The last week I reviewed all exhaust duct, including cat and muffle. They are good. And what about the Point X? It doesn't let me pull totally the carpet up. What is that point? Regards,
  7. Hello guys, easy exercise. I read this post yesterday and just today did it. I attach a MAF pic of my 93' SEV6 A/T (100 kmil). It was clean. Regards,
  8. Hello Guys, the issue continous. I attach you pics where I indicate the warm zone; there is a Ponit X (the hottest point) that I don't know what it is. What it is? What are there under carpet indicated zone? Regards,
  9. Does anyone have pics of that referred tool? Regards,
  10. Looking the O2 Sensor place, I saw a little kind of asbestos filler in the red zone of attached pic (Excuse me, it pic was taken from a post by Slick). Now, my Pathy hasn't that filler. It is a serious case? Shall I to refill it ? Regards,
  11. What is the best practice or procedure to review the O2 Sensor in my 93' Pathy SEV6 (VG30E) A/T ? Regards,
  12. There is any kind of plug to conect a scanner in my 93' Pathy SEV6 A/T (VG30E), or only is the ECU to diagnostic procedure? In manual maintenance book there is a sketch referring to "Check Connector for ECCS Checker Box". I tried to connect a scanner there but it didn't read anything. Regards,
  13. Just today reviewed my cat, but it is very good. Lack power contiunuous. Some sulfure smell. I'm disturbed. What another can I do ? Regards,
  14. In my area I haven't could find the pathy's cat. To buy a non-stock cat, what is its general specification?. There is any manner to fix the old cat?, or definitively it is went to waste?. Regards,
  15. And, what about the power and the MPG if I do without the cat? Incrase or down? Regards,
  16. Excuse my ignorance and my non technical curiosity, but I have a question: What does happen if I do without the cat? Regards,
  17. In addition (another symptom), there is a sulphur smell exhuast in my Pathy. Regards,
  18. How can I know if definitively is the cat ? If is the cat, what is the solution? Harmed cat could be part of my lack power problem? Regards,
  19. SteeevO, then what happened with your "Hot exhaust..melting carpet..carpet on fire!" issue?. It was caused by the cat or not? In my 93' Pathy SEV6, I have a similar problem : Lack power, rear passenger carpet warm, sulphur smell exhaust. Regards,
  20. I have a 93' Pathy SE V6 A/T (VG30E). 100 Kmil After driving for a half hour, I noticed the parking brake bar was warm. It was strange for me because I was driving with A/C on. Then, I noticed the carpet on rear left passenger was warm, too. On the right passenger was normal. What that means?. Is possible there is a problem in any exhaust duct part? Thanks,
  21. Then, in technical terms, why were designed "1", "2", OverDrive-OFF and POWER positions? (They look redundant).
  22. I have a 93' Pathy A/T (VG30E). I'm not sure when I shall use "2" or "1" positions, or the OverDrive-OFF, or set power shift switch on POWER. I use driving all time in "D" position. Does anyone guide me, please?
  23. Could I use the 94 Pathfinder Manual for my 93 Pathy? I read it and didn´t find diference (on paper) betwen both models.
  24. Hi. I´m a new pathy owner. I read this post but for me doesn´t clear what I have to do. Two weeks ago I´ve been having the same problem (an oil leak and it look's it come from the rear crankshaft seal). How I can be sure if it is the rear crankshaft seal? When the truck is parked there is no leak. Is recommended to prove some type of oil additive before a mechanic work?. My pathy is 93´ 4WD Automatic Trasmission, 99700 mil. Where I live temperature is 38ºC (100 ºF) all time.
