WRL69
93 Pathfinder SE V6 Automatic Transmission Mileage : 99700 (today) I got it one month ago. I´m 2nd owner. Excellent. White.
Screwdriver Mechanic
36-40
Do Not Go Off-Road
1994
WRL69's Achievements
NPORA Regular (2/5)
In my 93´ A/T Pathy, when I sptop the Idle speed downs to cero. Could anyone tell what means that? and, What I have to do to resolve that case? Regards,
Does anyone know the number part of that sending unit ? Thanks.
Could anyone tell a good Nissan dealer in Miami or Ft Lauderdale, to buy those parts ?
Sorry Simon, please explain me each one of parts that compose the whole sending unit. Thanks.
In my Pathy SEV6 93`A/T, the gasoil indicator level on instrument panel, is dead. The indicator needle of gasoline level in the instrument panel always is in the lowest point, thus it is that the gasoline tank is full. I reviewed the integral card united to gas pump in gas tank, and I believe that card is dead. Please, Could anyone tell me what I have to do to change it (because I don't believe is possible repare it); how I can DIY. Please the reference number of that card to buy. Thanks,
I have to replace any gasket (number part; quantity) ? What is the proper proceure to do this important work in my Pathy?
In another same topic, I read the number part of washer is 14037-V5005. What is the correct number of this part, or, it is diferent to 93' Pathy? Regards,
I am planning to change the studbold of manifold in my SEV A/T 93' Pathy (VG30E) Please, could anyone inform me the quantity and number part of each spare part I have to buy to do it? (300ZX studs, nuts, washers, gaskets, etc.) Could anyone explain the best procedure and tips to do it? Some pics? Thanks.
I have a 93 AT Pathy. In the maintenance instruction manual and in cap of brake liquid pot I read I have to use only DOT 3 liquid Brake. What hapen if I use DOT 4? What hapen if I mix both DOT 3 and DOT 4? Regards,
Any comment?
It is possible that installing the new coolers the capacity of cooling of the radiator is diminished? Regards,
Good pictures. Although, how can I recognize which it is the out line from AT ? and, What specifications of coolers I shall to use to buy them (dimensions, material)? The average temperature where I live is 38ºC (100 ºF) and 80% humidity, so I think I am needing those coolers. My Pathy is a SEV6 AT 93. Thanks,
Has anyone pics with installation of AT cooler, and more information about accesories required to install it.? Thanks.
I got it. Thanks.
Yes, my Pathy is Auto. Regards,
