wilson
About wilson
  • Birthday 11/23/1977
    94 4wd
    Screwdriver Mechanic
    Choose
    Rarely Go Off-Road
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
wilson's Achievements
NPORA Veteran (3/5)
  1. what is the hooha worth new and where do u order them i need one my truck is waiting for a new one for inspection i cant drive it now
  2. right on, that sounds like what I got going on.
  3. alkorahil, I recently pulled a blue 18 tooth out of the junk yard and found that it wont engage when I put it in my truck. I wouldn't say it was light blue, would an early blue 18 not work in a 94?
  4. just kept smacking that that puppy. eventually came off.
  5. I have a seized slide pin on the the passenger rear wheel. it is the top pin and is part my off. any suggestion other than pb blaster and beating the piss out off it? Ive also taken the rubber plug out of the inner side and have been shooting pb blaster n there as well.
  6. I just replaced my stock 20 tooth gear with an 18 tooth. as I suspected, the speedo now doesnt work. how can you change gear sizes without changing the spacing between axles the gears spin on? or am I missing the trick to get the gears to engage?
  7. mounted a roof rack using well-nuts.so In reality I have (8) 1/2 in ch holes in the roof!!! hilarious. now I'm not sure I like this solution. I think the rubber areas will wear through over time with any serious weight up there on a bumpy road. I really just want to reduce the size if the holes, so Ican just put some smaller bolts through it. ahardbody where can I get that thing? it is exactly what I'm looking for!
  8. you know of any good source that show how to do this?
  9. So Ive done something stupid ...again. I'm now lookin for ideas to fill a 1/2" hole in my roof. I have no access to a welder. bondo?
  10. yes! that is what I meant! haha. I too have 7 marks thanks for this info. its all coming together now.
  11. awesome, the mark for TDC being 0, or the first mark on the flywheel?
  12. Sorry, it is what the manual refers to as the left hand cam sprocket. meaning drivers side.
