howlerman
    91 Pathinder SE Auto.
    Screwdriver Mechanic
Contact Methods
  • Website URL
    http://
  • ICQ
howlerman's Achievements
  1. I have a 91 4 door with spare carrier, installed the JGC coils from a JY, gave me about 2.5" of lift, I also have a 50 lb sub box and trail gear in the back, which prob doesn't help. Been on for about 5k miles or so and has not drooped yet. Over all very happy with the results considering it cost me little $$ and some elbow grease in my driveway
  2. I can attest to this fer sure My pathy was stolen from a locked underground parking lot at 1pm. Cool thing is, I told a bunch of people and my dad spotted the crackheads driving it, he called me, I then called the police, hopped in the girlfriends car and went to the last seen location....I came just in time to see the officer questioning the driver and even told him "hey thats my truck officer. Was very nice to watch the thieves get hauled away in chains Pathy took some paint damage on passenger door, door lock was mangled and they hotwired my ignition. Other than than having all my tools and personal gear scattered everywhere, all was ok Insurance covered it all and I even paid zero deductable Worked out pretty well I would say
  3. I just did mine on the weekend took me like 2 hours I am by no means an expert and found this job very easy to do, just follow the steps here which I found on this forum; http://www.damagedreality.com/fordcoil.html I got the coils from the junkyard for 15$ each (CDN) The JGC coils added about 2" of lift, I also have a 91 with spare tire carrier and a sub box with tools in the back I also carry and 16 foot aluminum canoe up to remote lakes all the time so I needed some stiffer springs I also replaced the rear shocks. The stock ones compressed by hand very easily, unevenly and made sickly squishy sounds, I am sure they did nothing at all
  4. I used these shocks 324509 (rear) 322500 (front)
  5. Yeah I ordered the longer shocks, no extra cost
  6. Yes they for sure need to go. Angle grinder made quick work of them Only small issue I had was with the rubber spacing thingies (unsure of the name) that go on each end of the shock, the passenger side bracket is thicker than the centerlink ubolt bracket, so to get the nut started on that side of the shock I had to compress the rubber parts with a pair of vice grips so I could get the nut started. I am putting some JGC springs I obtained and new shocks this weekend to lift the rear Stoked! Good luck in installing yours
  7. Just installed the Pro Comp Steering Stabilizer that came as a bonus with 4 Pro Comp 3000 shocks The mounting kit came with it, installs just like the Rancho SS, had to grind down the centerlink tabs, in fact I think the mounting brackets are identical to a Rancho kit, just a different shock. I may post some pics later after I do the JGC coil lift with the new shocks What a difference in the handling! Especially at highway speeds when the wind is gusting and passing by big rigs, works great on the rough roads too! Very happy over all :cool2:
  8. I plan on doing the JGC rear coil lift and Roughcountry A-Arm torsion lift My question is are the shocks the same for the front and rear, I will be replacing my stock shocks. I looked over the forums and found the part numbers here; http://www.nissanpathfinders.net/forum/index.php?showtopic=9988 Should I use the slightly longer shocks for the rear and stock specs shocks on the front? Or use the same on front and rear? Thanks in advance to the Pathy gurus :bow:
  9. Thanks Going to gert the idler arm brace, I will post some pics when I done
  10. I am stockpiling parts for a 2-3 " lift on my stock 91 Pathy. Plan on using JCG coils I have, Roughcountry A-Arms, Rancho shocks and possible a steering stabilizor. Maybe go up to a 32" X 11.50 Tire From what I can tell I should not need new break lines/extensions.... Anyone have any advice for a backyard mechanic on a budget who plans on doing this lift or any other mods? This site is rad, lots of knowledge and some wicked rigs Thanks for the info
  11. This happened to me at a most unfortunate time. I was out wheeling with a buddy, and stuck the Pathy in camoflaged mudhole up to passenger side mirror, had some water inside the passenger side just shy of the ECU. Got out of the vehicle with it running, doors locked on me. Ended up having to take rear passenger window out to get back in. Top it off my buddys XJ had no tow points due to crappy unibody and could not pull me out witht he tow strap I had. Found some help later from a guy and a small tug pulled me out. Anyways I have a magnetic key holder now and hi lift jack with tow strap at all times(works until I can afford a winch) Took some TLC to clean out the mud from interior but I still love the Pathy and keep adding mods here and there. Thats my door lock horror story
