sonyslave
Impressively reliable daily driver. 144,000 on the original headlight bulbs.
36-40
Rarely Go Off-Road
XE
1996
Gender
Hawaii
sonyslave's Achievements
Will try that should the unit fail to power up again! Disconnecting the CD unit could save the radio... Just fyi, in my case the entire radio/cd/cassette seemed to be not be getting any power, display would remain off when hitting the power button.
Yeah, strange that pulling and reinserting the fuse fixed it. Maybe something loose in the fuse box, though everything is stock and the vehicle is stored in a dry environment. 22 years old, so odd things can happen....
2003 R50 with OEM 6 disc changer and cassette player/radio would not power on. Pulled the radio fuse (fusebox on left side of steering wheel), still good, reinstalled fuse. Turn on key, radio still won't power up. Pulled the 'amp' fuse (fusebox on left side of steering wheel), was still good, upon reinstallation of amp fuse the 6 disc changer start cycling through 6 disc holders -even with the key off(well, ...90% sure the key was off) Turned on key and the radio powered up. No idea why, but radio works again (cd died ages ago, probably laser or laser transport is broken)
Thanks! It took a while to figure out. I have not done much work on brakes, however hydraulic systems are pretty straightforward if one considers a master cylinder to be basically a syringe with 2 exits. -Also just fyi (don't want to give anyone the wrong assumption) when the brake pedal goes all the way to the floor that is not usually symptom of brake booster failure, typically it could indicate a master cylinder seal failure.
- 3 replies
- brake booster
- wheel cylinder
- (and 4 more)
This was on an '03 2wd The brakes suddenly were not as effective. Had to stand on the brakes and even then, much reduced braking force. With the engine off the pedal would sink to the all the way to the floor. I thought the master cylinder went out since there was no hydraulic resistance felt at the pedal with the engine off. First: I inspected for leaks and found one rear wheel cylinder had a small leak. The exterior of the drum housing on the side facing the pumpkin had a barely discernable, small damp spot in the grime near the bleeder nipple. That wheel cylinder was bad, fluid weeping past the rubber seal, clearly visible when lifting the outside lip of the rubber seal. I swapped in a new wheel cylinder (fyi you don't need to take apart the brake shoes, just crank open the adjuster. After install is complete you have to crank it back closed while holding open the one way stopper arm) I power bled that line at the wheel cylinder -it was strange because it was difficult for the power bleeder to get a lot of fluid out of the line -but eventually enough came out that I considered it to be air bubble free. The pedal was still sinking to the floor... I slightly cracked each line (2 lines) at the master cylinder connection (while pedal was being depressed) to see if there was pressure passing out of the MC, there was. So I assumed the MC was good. I power bled more at all 4 corners TWICE pumped brakes with engine of and on, and still, not a lot of fluid was coming out, but enough that I thought maybe there are no air bubbles. Next I pumped pedal with the engine off, the pedal was firm, a good sign that the system was holding pressure and bubble free. Next I test drove and noticed an air hiss under braking, this is a telltale sign of a leaking brake booster. Next I swapped in a new brake booster and all is well. Theory: the rear wheel cylinder failed and allowed air into the line creating the sinking to the floor brake pedal. Then: maybe full extension of the brake booster under repeated 'pedal to the floor' strokes caused the brake booster diaphragm to tear? Takeaway: the master cylinder is fine despite the symptoms being indicative of a failed MC. Also: this is the 2nd replacement brake booster for this vehicle (master cylinder showed no leaks). 1st replacement BB was from O'Reilly's, a remanufactured unit from China bought in 2019, and was garbage, it start having a rubber squeak sound 2 weeks after install, and failed at 5 years. Upside, lifetime warranty on the original purchase, 2nd BB was no charge (reman unit for Mexico) -but not sure if the lifetime warranty applies to the replacement part. If you diy this have various extra ratchet extensions and wobblers on had, also deep well sockets. Working under the dash is a bitch so allow extra time.
- 3 replies
- brake booster
- wheel cylinder
- (and 4 more)
MOOG strut mount bearings after three and a half years...
sonyslave replied to clkindred's topic in 96-2004 R50 Pathfinders
Thanks! I went with the Moogs too. Prob only about 15k ago. No problems. -
Toe adjustment: how many turns = inch/degree?
sonyslave replied to sonyslave's topic in 96-2004 R50 Pathfinders
Thanks Slartibartfast, yep gonna bite the bullet and do that today. Will post my findings. -
This method is not perfect, but it is easy for you to to do by yourself and gets your toe alignment set fairly accurately provided you don't measure incorrectly. Tips: Gorilla tape holds fast to the tire. Use a flexible, light weight tape measure (mine was a freebie from the bank), or perhaps a cloth tape measure that flexes easily. Do not thread screws into the tire, just barely go into the tread block, this step is not necessary but it makes it easier to check that you are setting the tape measure on the exact same plane for an accurate measurement. Set 1st screw in tread. Measure distance to floor, use this distance to set the 2nd screw at a similar distance to floor -doesn't have to be perfect, just close - because this method measures difference. I like to mark the position and the measurement value on the tire itself to make things simple, use a pen mark traced on the tire. This helps to remind yourself if you are lacing the tape over or through the tread blocks so you can duplicate the lacing for the 2nd measurement. Roll Pathfinder to 2nd position for measurement, leave screws in place while rolling. Do not roll over screws. Retract tape measure and leave tape measure attached (taped) to tire during rolling, do not run it over. NOTE: the tape measure is still on the SAME SIDE of the screw relative to the screw. -don't lace the tape measure along the top(or bottom) of the screw for both measurements. The tape has to be in a straight line under the vehicle, obstructions to the tape forcing it to wrap/bend around will err your measure. The closer to 180 degrees out for the 2nd measurement will the aid the accuracy of the measurement. I can't take credit for this method, it was originally posted elsewhere -using pins/needles in the tread and measuring the distance between the pins. Seemed too difficult to do by myself so I modified it to this method. Hope this helps out somebody, I've gotten a ton of help from NPORA!!!
Doing a quick and dirty alignment, does anyone know the ratio of turns on the tie rod vs. inches/degrees of adjustment at the wheel? I have Moog tie rod outers if that matters...are all manufs standardized as far as threads per inch? So many questions... Thanks in advance for any help!
What is the brand of the stock oem pads?
Thanks for passing that along Alkorahil! I'll check out those Nismo pads, great price! I try to stick with Japanese made replacement parts, usually they last longer than other brands. -
Thanks all for the help and input. I wanted to stick with stock because based on what I've read the manufacturers put a lot of effort into optimizing pad performance and rotor life, often their oem pads offer the best trade off between the two. I originally checked rock auto, just wanted to confirm with others that the Akebono brand was the stuff Nissan would use. Thanks!! -
Anyone know? Thanks! I'm swapping pads and want to stick with what Nissan uses. ....Yes I did a search, -a short one.
Nice! Like the door moulding too!
Looks sharp! Nice job.
