Maz
    1991 pathfinder
Maz's Achievements
NPORA Veteran (3/5)
  1. Maz
    York OBA
    make sure you get the right york compressor check out www.onboardair.com for some info. I am running the 210 on my mazda with 4 cyl for my airbag suspension and it's great and very fast especially at high idle. You can get em from the the wreckes for pretty cheap under $50
  2. Check the intake strainer not sure if pathies have em though. or water under the cap
  3. We lost our only key for our honda took out the lock cylinder and took it in and there is a code on it for them to make a key. If that doen't work they can make a key from the lock cylinder. it cost less than $20
  4. probably your thermostat isn't working. Does it blow hot air in the vents. It should get pretty warm in the cab after driving for awhile. If it's just warm air it's probab;y your thermostat. Replaced mine and now the guage reads aproz 1/2 and have a nice warm cab
  5. the brake wiring is very easy. If you have basic wiring skills. The hardest part was finding a place in the firewall to go through. I did it on my 91 to pull my Bigfoot RV. I think you only need 1 wire (blue?) that runs from the brake controller the the 7 prong round plug. All the stuff I bought was labeled as ti what and where it was for.
  6. what's the resiatnce range for plug wires on my 91 thanks Jamie
  7. I have a fairly light trailer under 2000 lbs and the gas milage goes way down almost half
  8. you may get lucky and not need an extension I didn't on my 91
  9. I am wanting a 2001 plus frontier as well in the mext year or so... I want the 4 dr s/c so it still has some space inside as well as a bed. Does the S/C only come in certain trucks or all of them? Thanks Jamie
  10. Found where the clutch fluid was going............onto the floor went and got a new master cylinder but need a line wrench to take off the line cause it's gonna strip so I am too lazy to go back downtown and buy one.......itll have to wait till tomorrow. And I have paurchased my bodylift for my 91 and have found some bolts in stock @ acklands only problem is that they are 190mm and a allen head but nothing a washer can't take care of. Later Jamie
  11. I broke mine with a hammer then slid the socket over it and managed to get it back in with a wrench. Still didn't fix my problem though. Something in the tranny isn't engaing the switch
  12. yeah thanks I Am wanting to center my rear wheels is this the best way?
  13. I am wanting to extend my rear trailing arms so the axle is centered I looked for the pics but couldn't em. ANy help would be great Thanks Jamie
  14. check your exhaust manifold studs mine squeals outta the passenger side by the firewall cause it broke only does it on deceleration. Later Jamie
