armelius2
Everything posted by armelius2
That plastic was a part that rested on the brake pedal assembly. So that the switchs would touch it when the brake pedal is released. Turns out I didn't need a switch eventhough I bought one anyways. I just took some metal bolts and put double sided electrical tape through the bolt and placed them in the holes. This is probably why my cruise control hasn't been working. Going to take it for a test drive now.
Yeah, there is a switch near the rear transmission you have to really get awkward to replace that switch.
Just happened today. Looked it up in the book and it might be the stop lamp switch just above the brake pedal that needs replacing. Though I did find a piece of cracked plastic on the foot board which might be the part on the other end or one end of the clevis pin. Any thoughts on this? When I take the wires out of the stop lamp switch the lamps go out. But that plastic sure has me thinking the clevis pin plastic retainer. Only it's a dark blue.
Is The Engine Shaking The Truck Normal At Idle?
armelius2 replied to armelius2's topic in 86.5-89 WD21 Pathfinders
Nope. Mounts not fixed. Don't know how much that would cost me. I looked under the engine and it looked like one mount might be busted, looks kind of cracked inside. You can probably just clean out your PCV valve rather than replace it. They are fairly cheap though. It's definately something you should do. -
Guages Going Up For Sale For 88 Pathfinder
It's now up for sale in the classified section of this forum. Price is 51 dollars delivered. -
It might be the mount. It's not shaking real bad but you would notice that antenna movin. Have to check it tomorrow. -
Thermostat change, new spark plugs NGKs and wire set, replaced pcv valve and the hoses which were on their last leg. It doesn't do it anymore.
As everyone probably knows I have the coolant temp. guage problem. I bought this item off ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=7955050089 It looks good and nothing has been done to it and after the other guy gets a chance to buy it I will offer it up for sale Sunday for what I paid for it. The voltage connectors do not fit on my 87. Plus I have found that one of my wires have been pulled from the connector and that there might of been a short between the 8 volt voltage regulator. Just looks like it has some burn or rust marks on the flexible wiring. So there really isn't anything beside bulbs that I could use on this thing and I definately don't need bulbs. On the plus side I got one of the mileage indicators working again. Don't know how I did it but I am glad I don't have to write down the mileage between fill ups anymore.
I like that. The cost of changing a timing belt you can buy a new or fairly new v6 on ebay.
armelius2 posted a topic in 86.5-89 WD21 Pathfinders
Seems it needs tightening up or mounts or something. My antenna is shaking mildly. Anyone else? -
Plugs, wires, and timing?
That's cool. So what did you comp tell you?
I just put NGK's in mine. Replaced the autolites. Probably won't get the platinum autollites again.
I think my backfire is fixed.
I haven't checked but last time I did I was getting injector leak, 23 and 12 or 13 or something like that.
Too late already bought the hoses. My problem is same as CTPathy. Right about 15000 as the rpms decelerate and you punch it, the backfire occurs. What or where is the decel valve? I was thinking it might be the AB valve if anything. Haven't checked the codes after the plugs and thermostat install. Seems it's harder to get it to backfire though.
Nearly 250k.
I just changed my thermostat, spark plugs and wire set and 40 bux on two pcv hoses (one on each side, but just one pcv) and I still have some backfire at the throttle body.
Anyone Replace Their Timing Belt?
Hmmm, wonder if I should do it. -
Just wondering about how difficult this might be and if any special tools make the job easier. TDC seems like the hardest part.
One side is larger than the other. There is no generic or adapters.
That thermostat sure is difficult to get to.
Going to replace the thermostat. The pcv hose cost 20 bux and is three or more days away. BS.
A punch tool? I bought ngks spark plugs for the heck of it. Have to wait on this hose now. Anyone replace their AB valve? I really hate waiting for parts. I remember when if you had a foreign auto you had to take it to a specialist perhaps because of the metric system but you also had to wait weeks before they shipped the stuff on the slow boat.
O2 sensor? Right now I have to replace the pcv hose. That thing was very brittle at the ends and hard as chinese plastic.
