Guest traillooker Posted October 9, 2006 Share Posted October 9, 2006 (edited) My RPMs meter has gone bad. Some times it works and some times it will peg out. Has anyone had a problem like that. I'm thinking it could be a diode are transister on the board or bad conection to board. Thought anyone. (Tachometer) Edited October 9, 2006 by traillooker Link to comment Share on other sites More sharing options...
cdhicks99 Posted October 9, 2006 Share Posted October 9, 2006 Is that the same as a tachometer? BTW Link to comment Share on other sites More sharing options...
Guest traillooker Posted October 9, 2006 Share Posted October 9, 2006 Yes Link to comment Share on other sites More sharing options...
89_trailboss Posted October 9, 2006 Share Posted October 9, 2006 year? and HELLO Link to comment Share on other sites More sharing options...
RedPath88 Posted October 9, 2006 Share Posted October 9, 2006 Welcome to the Forums Look at his profile, it is a 1997 Link to comment Share on other sites More sharing options...
Guest traillooker Posted October 10, 2006 Share Posted October 10, 2006 The year is 97. Link to comment Share on other sites More sharing options...
Smithk Posted October 14, 2006 Share Posted October 14, 2006 Hello, I've got a '93 and my techometer acts up on ocassion to, I've discussed it many times with my buddy who works for Nissan and he's checked all the cables and says nothing seems to be the problem but his solution was to order a new techometer for $500 and that might solve the problem. Link to comment Share on other sites More sharing options...
Slick Posted October 14, 2006 Share Posted October 14, 2006 hello and welcome.. check the connection for any loose/touching wires Link to comment Share on other sites More sharing options...
bear claw Posted October 17, 2006 Share Posted October 17, 2006 Join the club. I also have the same going on with my 95. It starts ok than it goes up and sticks till the next motor rev and goes up again and sticks again, until the thing is all the way to the max red line and remain until I park it. I thought I was killing it the first time I looked at it but I now got us to it and I'm much more relax about it lol My cure: dont look at it sorry this is all I got Link to comment Share on other sites More sharing options...
fordsho90 Posted October 18, 2006 Share Posted October 18, 2006 welcome Link to comment Share on other sites More sharing options...
weight weenie Posted October 25, 2006 Share Posted October 25, 2006 Hi all! I'm not sure if a '97 could have the same problem with the tach, but all you '95 & older owners may experience something like I have. My '90 Terrano ( it's an rhd pathy with a 2.7 turbo-diesel, as Canada allows 15-yr olds from overseas to be imported ) has the same sticking needle thing described by Bear claw. I took my cluster lens off to discover that years of sun & heat had warped the needle so that the tip was dragging on the guage face, leaving a light rub mark on the outer perimeter of the tach face. A temporary solution was to simply bend it back with my fingers, which worked for a short while but didn't last. I then overzealously snapped it off on the 2nd attempt, forcing me to the wreckers yard for a suitable replacement. Anyway, that's my windy story for today. Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted October 25, 2006 Share Posted October 25, 2006 Get an aftermarket gauge like an Autometer one... cheaper than a new Nissan one Link to comment Share on other sites More sharing options...
Smithk Posted October 26, 2006 Share Posted October 26, 2006 Get an aftermarket gauge like an Autometer one... cheaper than a new Nissan one Nissan new ones are $500 CDN like hell I'll use your suggestion but I just like the clock in the bottom of it to tell time. Link to comment Share on other sites More sharing options...
QuismO Posted October 26, 2006 Share Posted October 26, 2006 according to the factory service manual, the tach is controlled by a signal from the ECM, which is located behind the dash right above the gas pedal...check that there is continuity between terminal 3 and the wire going into your tach. then check that the signal varies when you turn on your car and rev. if the signal's good, your tach may be bad. try a local junkyard for pathies before going to the dealer. Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted October 26, 2006 Share Posted October 26, 2006 Nissan new ones are $500 CDN like hell I'll use your suggestion but I just like the clock in the bottom of it to tell time. Um, $94 USD from summit racing. thats considerably less than the price of the OE tach. I hope that was not directed at me. http://store.summitracing.com/partdetail.a...15&autoview=sku Link to comment Share on other sites More sharing options...
Splinter Posted October 31, 2007 Share Posted October 31, 2007 Um, $94 USD from summit racing. thats considerably less than the price of the OE tach. I hope that was not directed at me. http://store.summitracing.com/partdetail.a...mp;autoview=sku I think the way that was supposed to read was " Like hell (pause) I'll use your suggestion" Sort of like " My suit is blackpausenot" in my best Borat voice. Doin my best to keep the peace. Link to comment Share on other sites More sharing options...
