Charlie_Brown Posted January 28, 2018 Share Posted January 28, 2018 Anyone know what this is for and if it is a fusable link or just a Connection? Can I bypass it and wire straight onto the battery post or like I said is it a disable link? Link to comment Share on other sites More sharing options...
SpecialWarr Posted January 29, 2018 Share Posted January 29, 2018 Photos? Link? Link to comment Share on other sites More sharing options...
Charlie_Brown Posted January 30, 2018 Author Share Posted January 30, 2018 It is literally the connection box that connects to the positive terminal right at the battery. I took it off and apart and it's not a disable link it's just a connection for anyone else who may want to know. Ended up a wire pulled away from the connector so just the insulation was connected in my case. Link to comment Share on other sites More sharing options...
OH6PILOT Posted January 30, 2018 Share Posted January 30, 2018 (edited) Actually, it's a Fusible Link. Edited January 30, 2018 by OH6PILOT 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted January 30, 2018 Share Posted January 30, 2018 (edited) The BLACK section is just a connection point to the main terminal. The fusible links are the red and green wires AFTER the black box. If you notice, there's a second connection at the other end of said red and green wires. Edit: here's the fusible link from said connection. Sent from my SM-G920V using Tapatalk Edited January 30, 2018 by RCWD21 2 Link to comment Share on other sites More sharing options...
Charlie_Brown Posted January 30, 2018 Author Share Posted January 30, 2018 Yep, black box is just a connection however I was unaware that the red and green wires were fusible, I figured that was in the next set of connections immediately after. Good to know Link to comment Share on other sites More sharing options...
RCWD21 Posted January 30, 2018 Share Posted January 30, 2018 (edited) If you do decide to alter the connection right there keep the fusible links as close to stock length as possible. They're a certain length designed to give at a certain load just like a regular fuse would but if they get too short then the regular load pulled by the system will be too much essentially turning it into a smaller amperage fuse. Sent from my SM-G920V using Tapatalk Edited January 30, 2018 by RCWD21 2 Link to comment Share on other sites More sharing options...
Charlie_Brown Posted February 3, 2018 Author Share Posted February 3, 2018 That is good to know lucky at this point I don't need to mess with them and their lengths bit in the future I'll have to remember that Link to comment Share on other sites More sharing options...
