Dutchman Posted February 19, 2014 Share Posted February 19, 2014 Hey guys what would cause my abs light to suddenly apear on the instrument panel. And how can I fix this problem? any suggestions would be appreiated. Link to comment Share on other sites More sharing options...
Precise1 Posted February 19, 2014 Share Posted February 19, 2014 I guess there is an issue with the ABS then... What I recommend and would do is download the Factory Service Manual (pinned in the Garage section) and follow their trouble shooting procedure. I'm certain that is the best place to start. B Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 20, 2014 Share Posted February 20, 2014 Also check the fluid level in the brake master cylinder. I don't remember if it was the ABS light or the BRAKE light but one of 'em came on when my MC started leaking. Link to comment Share on other sites More sharing options...
FeelthePathos95 Posted February 20, 2014 Share Posted February 20, 2014 Easiest fix is just that your fluid is low. Top it up and the light might go off. But then you need to figure out why you might be losing fluid. My second thought would be bad sensor. I've had vehicles where the sensor went bad and one where the sensor was fine but the wire leading from it frayed and so the system was no longer getting input and that triggered the fault. Link to comment Share on other sites More sharing options...
Inyourface1650 Posted February 20, 2014 Share Posted February 20, 2014 master cylinder fluid low is ABS and BRAKE lights at the same time. Link to comment Share on other sites More sharing options...
