2003 Pathfinder SE 4X4 V6
45+
Rarely Go Off-Road
2003
Gender
SC
Country
699 profile views
Micallen's Achievements
I used to flush coolant by running engine with radiator drain open, water hose in top of radiator constantly filling. After several minutes of that all the existing coolant is replaced with tap water. Then I would remove hose, let it run another minute or 2, then turn engine off. Then of course I would close radiator drain and fill with coolant/water mix. Is that OK with the path finder? Or would I theoretically need to "Flush" it with distilled water??
Looks good.
I think I am going to remove all the OEM (head unit, amps, speakers, speaker wire) and replace it. I hear running speaker wire to the doors is no easy task.
I programmed one of the new fobs yesterday. The other one was dead. They are sending me a new one to replace it. So sometime this year I'll get a second key. I'll check with Ace Hardware and a few locksmiths locally.
Just picked up a 2003 Pathfinder LE 4X4
Micallen replied to Micallen's topic in New People Start Here!
Anyone familiar with the General Grabber UHP's? Getting a set put on this Friday.
Other than the steering wheel adapter, what adapter(s) do you need? Also, what stereo did you go with?
When I search for replacements on Crutchfield, it only shows single DIN. I have the Bose with 6 disc changer. Sure looks like double-DIN to me. What gives?
The 3-button fob is what I have. When I click on the 4-button one, it says it won't work for my vehicle. As far as the key, I have one, and would like one more as a spare. WHat's the process??
Will this key fob work on a 2003 Pathfinder? Sure looks like it will. https://smile.amazon.com/USARemote-n-u15-3btn-Frontier-Pathfinder-KBRASTU15/dp/B06XR3FSZZ/ref=sr_1_1_sspa?ie=UTF8&qid=1523629702&sr=8-1-spons&keywords=2003+pathfinder+key+fob&psc=1 And while we're on the subject, will these keys work? What is involved in programming the keys?? https://smile.amazon.com/Discount-Keyless-Replacement-KBRASTU15-CWTWB1U733/dp/B01BKS2LIE/ref=sr_1_23?ie=UTF8&qid=1523629783&sr=8-23&keywords=2003+pathfinder+key+fob Micallen
If you haven't downloaded your FSMs, better do it soon...
Micallen replied to hawairish's topic in General Forums
Thank you. Just downloaded mine too. -
It seems to be in pretty good shape, and only has 144,000 miles. Looking forward to learning all I can about it here! 😀 Micallen
