About Sagittarian
- Birthday 12/08/1963
SE V6, Sport/Power Package, Champagne Beige, 5 speed, Limited slip diff, 4 wheel disc brakes.
Skilled/Experienced Mechanic
45+
1991
Gender
Missouri
Country
Interests
Camping, Hunting, Fishing, Shooting
1,740 profile views
Sagittarian's Achievements
As I stated, I'm looking to get away from a computer. The reason I'm looking at the 4.3 isn't b/c of the 160 hp. It's b/c with minimal effort it can be around 300 lb-ft. If that block goes bad, I can pull the intake and heads, put them on another block and still be at that 300 lb-ft.
I'm simply attempting to eliminate the need for a computer as much as possible. The 87-95 4.3 came with TBI, which I can replace with an Edelbrock intake and 4bbl carb. I chose the 4.3 b/c of availability and baseline hp and lb-ft.
I don't need a computer for a carb
It is something that I might look at again later... With a late model 87-95 4.3 I can get 160hp 235lbft. I can also change the intake and swap out the TBI for a carburetor and get rid of the computer.
Due mostly to all the necessary custom work involved. I'm not in a position to undertake something of that nature.
I haven't looked for the sticker, but I do know it pulls pos just from playing on gravel roads.
Yeah, I forgot put head work, but that's what I thought. Rough guessing, after all that would put it about 190ish hp and 220is lb-ft?
It seems that the only way to pump up the power on a VG30E w/o adding turbo is remapped ECU, headers, air filter and exhaust. Is that about correct?
After researching... definitely not going that route!
In my research of my 91 pathy, I noticed that nissan used a detroit locker on some models, Is there a way to tell if mine has one other than taking the cover off?
I am interested in putting a 4.3L v6 into my 91 pathy. The primary reason is because I doubt I'll be able to get the HP and Torque out of a vg33e conversion, unless I put a truck load of cash into it and then I'm not sure it will be as cost effective as just converting over to a 4.3 The vg33 is rated at 180 hp and 202 lb-ft. The 92-94 L35 4.3 is rated at 200 hp and 260 lb-ft I know I'll need to swap out the tranny and the transfer case I guess my question is, is it feasible?
http://www.nissanpathfinders.net/forum/topic/9142-poor-mans-lift/
Anyone know where this rig is and any details on its build?
Sagittarian replied to djeffrey's topic in 90-95 WD21 Pathfinders
I'm curious to know what suspension is being used and what other "mods" it has -
I am thinking of putting 31x10.5 on 16" wheels but it seems like a wash for weight. the 16's are 4 lbs heavier than the 15's
Is there any benefit to with 16" or 17" wheels over 15" wheels?
