kdj
kdj last won the day on April 28 2016
kdj had the most liked content!
About kdj
  • Birthday 07/29/1918
    2003 Pathfinder
  • Place of Residence
    Ontario
    Skilled/Experienced Mechanic
    Choose
    Chilkoot
    Ontario
    Holy See Vatican City
kdj's Achievements
NPORA Old-Timer (5/5)
133
  1. Take the tire off and remove the Philip screws in the wheel well (5 or 6) Then pop out the upper tabs (4 or 5).
  2. I meant pull up from the outside while someone pushes up under the brace from inside.
  3. I took the Warn hubs off my '98 (floor shift) and put them on my '03 (dash knob). They work the same on both....lock the hubs then the shifter if that helps you?
  4. How about a toilet plunger or three? A couple of jerks might pop it up. I mean with the plungers(not helpers). With someone putting pressure just to the rear of the sunroof (inside) there is a brace there.
  5. kdj
    Gas gauge.
    Thanks...I guess I'll remove the dash and try another gauge, The tank is grounded. I pulled the sender out of the tank and plugged in one that I know works. It still reads over full even moving the arm. I have no studs just two plug in connectors to the sender.. It's a 2003 and I'm not sure which connections to check the ohms. Thanks for the help...my computer is working about as well as my gauge and I apperciate the help.
  6. kdj
    Gas gauge.
    So I guess no one knows anything about a non working gas gauge...Disappointing.
  7. kdj
    Gas Gauge
    Yes I use the trip meter but I have run out once after a loose battery cable caused it to reset the meter. I figured that out after I ran out. I'd just rather fix the gauge.
  8. kdj
    Gas Gauge
    I'm hoping someone can help me out. I have a 2003 with a gas gauge that has quit working. It goes to full as soon as the key is turned on. The tank is grounded and I have tried pluging in another sending unit and it reads the same. I cant see the gauge itself failing. Is there a relay in there some where that might have failed. I've had to replace the one for the blower and one for the front amp, so I could see another one quitting. I have a wire diagram but can't find anything. Any ideas? I don't like carrying a can of gas with me...just in case. Thanks
  9. In my opinion as a welder... you don't "repair rust"
  10. I've never heard of someone that wants rusty photos.
  11. He last posted January 14 2016. He must be on lunch break.
  12. I wire brown,yellow, green and white. What is a "box" for? I have signals, brakes and tail lights. Trucks X2.
  13. Now was he the guy with the cat eating a cactus? No disrespect. Sorry to hear of this.
