Tool for Trans and Diff Fluid Change
rennwerkes
Okay, I'm used to seeing an allen fitting on diffs so it looks like I'll need a pipe type of tool for the diff. Not sure about the manual trans but was hoping someone could tell me exactly what tool I need to R&R the trans fluid and diff fluid on my 91.
TIA! :D
A standard 1/2" breaker bar. The square fits right in the plug.
BTW, you should remove the fill plug to be sure you can refill it before you take the drain plug out. If you can't get the fill plug out you can always remove the shifter and pour the 5.1 liters down the hole.
Manual trans TSB
