Guest keith Posted July 17, 2006 Share Posted July 17, 2006 Ok, I live in Ecuador, and used 4wd´s are expensive. So, since cars don´t really rust here, and labor is cheap, it´s common to see cars from the 80s and early 90s, and they still cost 6-8k USD. Anyhow, I found this great 93 Pathfinder 4wd with 75k miles, but when I took it for a test drive, it seemed like the engine revved a lot for not much work. Also power was lousy. Engine sounds good and clean apart from this. The owner told me that it´s becuase it only has 4 cyl, not like American versions with 6. He also told me that they did a compression test, and got 125 on all cylinders. The car looks great and otherwise works great, so I´m even thinking about putting a 6 cyl engine in it, if I can find one here and it´s not too expensive or complicated. Questions: 1. Does 125 sound good for the compression? 2. Has anyone heard of Pathfinders with 4 cyl? 3. Would changing the engine size require a different transmission? 4. Any idea if I can just change it for a standard 6 cyl from another pathfinder? :confused: Link to comment Share on other sites More sharing options...
vengeful Posted July 17, 2006 Share Posted July 17, 2006 Yes. In every market other than US, the 4cyl models were more prevalent. It wouldn't surprise me at all to see a 4banger one in Ecuador. 125 sounds right. 3. Yes, swapping the engine will require a new transmission that will bolt up to the new engine. Yes, you can swap in a 6cyl from another Pathy, but it's still a lot of work. You'll have to switch the ECU, transmission, transfer case, as well as all the wiring and fuel stuff as with any other engine swap. Good luck. Link to comment Share on other sites More sharing options...
