rear clunk
Guest michaelanderson20
Does anyone get a rear clunk when they let off the gas? It is kind of like a pulsation coming from the rear driveshaft. As soon as you let off the gas the truck jerks like that driveshaft has play in it or something strange. I didn't know if it was normal or not. I checked under the truck and the shaft does have play (rotational that is). Anyone got an idea? Thanks!
Umm...What sort of Pathy do you have?
I notice it a bit in my '02, sort of like a clunk when I left off the gas, then accelerate again, as soon as tourque is applied to the driveshaft...
There should be a little play in the differential - the yoke can turn back and forth a couple few degrees.
But there should be NO rotational play in any of the u-joints.
