Guest bryan89 Posted April 10, 2004 Share Posted April 10, 2004 i have a 1989 Nissan Pathfinder i recently installed a rancho suspension lift (a-arms and coils) i also added sway-a-way torsion bars i torqued the new torsion bars to a little bit less than the stock ones because they are stiffer, but my new a-arms are resting on the bumpstops when the suspension is at rest (i.e. sitting in my driveway) it was even like that after i got it aligned please could someone with a similar setup tell me what to do to fix the problem before i get off spring break and have to drive to school? :confused: :help: i was thinking that maybe my torsion bars are too tight? is this correct and if so is there a way to draw the set bolt up into the frame without adding tension to the torsion bar?(like "un-indexing" as opposed to "reindexing") Link to comment Share on other sites More sharing options...
somethingcool Posted April 11, 2004 Share Posted April 11, 2004 Yeah just do the same thing as reindexing just turn the bar a few degrees in the opposite direction. But you'll probably need another alignment if you adjust more than 1/2" or so. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 11, 2004 Share Posted April 11, 2004 Mmmyep. You may have put the anchors on a bit too far forward. Link to comment Share on other sites More sharing options...
