unccpathfinder Posted June 25, 2006 Share Posted June 25, 2006 was wondering if any of yall had/knew about this tool that "allows" you to bleed the abs on camaros/trans ams...i looked on LS1tech and didnt really find anything except 1 guy taht said he did it and didnt have any problems... but the manual says u need a scanner tool to allow u to bleed the brakes and i dont see y u just cant disconnectthe battery and do it...but i dont wanna screw up his car if any1 has any idea that would be awsome... and the local shops wont let him pay them to bleed his brakes they have to do all the work with their parts...which i feel is stupid... Link to comment Share on other sites More sharing options...
Slick Posted June 25, 2006 Share Posted June 25, 2006 sssh what year camaro.. dave has a posi disk brake rear end from the trans am under his camaro..... Link to comment Share on other sites More sharing options...
Guest Thunderbox Posted June 25, 2006 Share Posted June 25, 2006 ok From what I was just reading its the same as bleeding an older camaro or TA Heres a write up on a 98 Trans am All the brakes are the same as a camaro.From what I think the scanner tool resets the brake code when the psi is lost from the abs.Heres the wrtie up Brake write up I hope this will help.I will keep checking Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 25, 2006 Author Share Posted June 25, 2006 slick its a 99...thanks for the help guys im gonna pass it on and see if he wants to do it Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 25, 2006 Author Share Posted June 25, 2006 did it and disconnected the battery and so far no light.... Link to comment Share on other sites More sharing options...
