Door help!
rennwerkes
Folks, it's the newbie again!
My driver side passenger door closes in a weird way. About four inches before the door closes there's some resistance to it. Just like it's hitting something soft. The door will close but there's a noticeable gap up top.
I've read that these doors can sag but mine seems to be aligned perfectly with the body, just doesn't close effortlessly.
Any idea's?
TIA!!!
check to make sure there are no broken pins in the hinge area or that the wiring is not catching on something as you're closing the door. sit inside the truck and slowly go through the motion of closing the door and see what happens ;)
