Drivers side engine mount removal
tmorgan4
I'm working on the lift in the garage, and I'm having some problems with the engine mounts. For those of you that have installed the lift, how did you get to the bottom two bolts on the drivers side engine mount? The differential is directly under it and right in the way...Any help would be appreciated. I can't go any further until I figure this out.
The problem with unbolting the whole subframe is it will rip the engine mount. After looking at it for a little while, I decided that the entire front drivetrain needs to be dropped to access it. Luv2ski on AC's board told me he did it without unbolting anything else. Maybe I just need to try a little harder...
