tmorgan4 Posted June 17, 2006 Share Posted June 17, 2006 I'm working on the lift in the garage, and I'm having some problems with the engine mounts. For those of you that have installed the lift, how did you get to the bottom two bolts on the drivers side engine mount? The differential is directly under it and right in the way...Any help would be appreciated. I can't go any further until I figure this out. Link to comment Share on other sites More sharing options...
4x4le Posted June 17, 2006 Share Posted June 17, 2006 i bet you gotta unbolt the whole subframe and let it droop a little Link to comment Share on other sites More sharing options...
tmorgan4 Posted June 17, 2006 Author Share Posted June 17, 2006 The problem with unbolting the whole subframe is it will rip the engine mount. After looking at it for a little while, I decided that the entire front drivetrain needs to be dropped to access it. Luv2ski on AC's board told me he did it without unbolting anything else. Maybe I just need to try a little harder... Link to comment Share on other sites More sharing options...
