r0x Posted June 1, 2006 Share Posted June 1, 2006 (edited) The AC in my 1998 Pathfinder cuts out after a minute or so. The air is ice cold at the beginning and then it just quits. Cycling the AC switch sometimes gives me another minute of cold air. Any suggestions? Another observation: the clutch seems to engage consistently. There is always an effect on idle RPM when the AC switch is pressed to turn it on. Thanks in advance for replies. --r0x Edited June 1, 2006 by r0x Link to comment Share on other sites More sharing options...
max_stryker Posted June 1, 2006 Share Posted June 1, 2006 does your heat do the same thing? if so maybe a blower motor? if not...go fast with the windows down lol Link to comment Share on other sites More sharing options...
sw Posted June 1, 2006 Share Posted June 1, 2006 (edited) prehaps sounds like the pressure switch in the ac system maybe a little dicky. possibly when you turn on the ac systems the pressure builds up pass specs. due to a dicky switch, then once it reaches a higher point it then cuts out. it then wont turn on again till pressure has dropped back down. normally they are located on the receiver/dryer (small rounded on both ends cylinder thats normally black & it will normally have the small sight glass as apart of it). maybe see if you can see what condition the pressure switch looks like its in however pressure switches in ac systems going bad, is sort of the thing that is very uncommon. but it could be a possibility edit: ahhhhh..... one way to rule out some stuff is to have the car idling with the ac on and pop the bonnet and watch the ac compressor clutch. you will pyshically see when its cutting in and out. Edited June 1, 2006 by sw Link to comment Share on other sites More sharing options...
dernt Posted June 1, 2006 Share Posted June 1, 2006 Your system may have a leak. They will cycle like you describe when they get low on refrigerant. Link to comment Share on other sites More sharing options...
r0x Posted June 2, 2006 Author Share Posted June 2, 2006 The blower motor is definitely good. Funny that you asked - for a while it was randomly cutting out and the fix was to replace the AC control panel because the fan speed switch was bad. I'll look into the other items. Thanks again for all replies. --r0x Link to comment Share on other sites More sharing options...
