Cold air intakes
nycxice13
no tubing required. The pop charger comes with an adapter plate that bolts to the stock intake (instead of the OE filter box) and the cone filter slides over it. but its a good idea to build a cold air box around the filter to keep out the heat from the engine. here's a link to an example on JWT's tech support site http://jimwolftechnology.com/wolfpdf/POPCH...BOX_EXAMPLE.PDF
I built a simple box on mine using aluminum, piece of cake. Sounds great too WHOOOOSSSSSHHHHH
