madhatter_xe Posted April 9, 2006 Share Posted April 9, 2006 (edited) Hey, does the crank sprocket just pull straight off? any tips on how to get the thing off? Edit: Also, do you need to pull the oil pump to change the crank seal?..god i hope not. Edited April 9, 2006 by madhatter_xe Link to comment Share on other sites More sharing options...
FLApathy Posted April 9, 2006 Share Posted April 9, 2006 you mean pully? the thing with all the belts on it? or im i just making myself look stupid?, lol Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 9, 2006 Share Posted April 9, 2006 The crank sprocket pulls straight off, yes. The crank seal is in the front of the oil pump, so no, you don't have to take it off. Link to comment Share on other sites More sharing options...
madhatter_xe Posted April 9, 2006 Author Share Posted April 9, 2006 (edited) Yup, just got er off. what a friggin weekend, did the valve cover gaskets yesterday only to find the leak get worse. looks like its the crank seal but oil sprayed everywhere so i should probably check the cams too. Thanks. Edited April 9, 2006 by madhatter_xe Link to comment Share on other sites More sharing options...
